ATMEGA328 Bootloader Programming Shield for Arduino Uno
Intro: ATMEGA328 Bootloader Programming Shield for Arduino Uno
ATMEGA328P boot-loader programming shield for Arduino Uno
Sometimes it happens and you damage your Arduino Uno Atmega328P microprocessor. You can change processor. But first it need to program boot-loader in it. So this tutorial how to make this board which upload bootloader.
If you don't want to make this board, look at this tutorial >>
https://learn.sparkfun.com/tutorials/installing-an...
To build this programmer you will need >>>
Parts:
1 x Atmega328P or Atmega328 PU microprocessor
2x 16MHz HC49S crystal quartz
2x 22pF 0805 ceramic capacitors
1x10K 0805 resistor
1x OR 1206 rezistor
1x 28 pin DIP socket
1x 40pins header pins
1x 75mm-75mm copper board
STEP 1: PCB Board
Design printed circuit board (PCB), I was used ,,Sprint-Layout" software. Exported Gerber files.
STEP 2: Soldering Board
28 DIP socket pins need to bend. I didn't want to drill holes.
After soldering this board it looks like this
STEP 3: Programming Atmega328P Bootloader
1) Open Arduino software
2) File> Examples > ArduinoISP
3) Tools > Programmer > Arduino as ISP
4) Sketch > Upload
5) Tools > Burn Bootloader
7 Comments
UtkarshVerma 6 years ago
You can also try this:
https://www.instructables.com/id/Burning-Bootloaders-Into-AVRs-Using-Arduino/
rfmdelgado 7 years ago
Eric Brouwer 7 years ago
A new ATMEGA328 is factory programmed (internal fuses set) to use it's internal 1MHz oscillator. Thus for a new chip, the crystals are not required to burn the bootloader.
Once the chip has been programmed with the Arduino bootloader, the internal fuses are set to use an external oscillator. Without the additional crystal used in this circuit, such a chip can no longer be re-programmed without a crystal.
Hope this answers your question.
I'be been delaying a shield like this but I think now I will build it
It will still work correct.
I have been using my programmer for a few years now, based on the same principal.
https://www.instructables.com/id/Arduino-UNO-as-AtMega328P-Programmer/
rpotts2 7 years ago
RimvydasP 7 years ago
I have a lot of 16MHz quartz, so it is easiest way for me to design pcb with 2. I know 1 quartz it will be better.
