Acetone and Styrofoam!
Intro: Acetone and Styrofoam!
Hi guys! I hope you enjoy this science experiment.
You need:
-Acetone
-Styrofoam
-A metal or glass container
Safety advisory:
Acetone fumes are flammable. Only do this in a well-ventialted area. Always wear safety glasses, and wash your hands well after handling acetone.
Have fun!
You need:
-Acetone
-Styrofoam
Safety advisory:
Have fun!
25 Comments
shawnleegabriel 1 year ago
rimar2000 10 years ago
Gasoline melts styrofoam, too.
Chikpeas Brother 10 years ago
True. I just went with acetone since it's more readily available.
WOW, here in Argentina it is on the contrary. Acetone is named "drug precursor" and then its market is controlled. You must declare the use you will make of it when buying.
By the way, the solution styrofoam-gasoline does not serve as adhesive. What is the case with styrofoam-acetone?
MagicTK 9 years ago
I used to make a mixture that was nice and gooey, and I could spread it on things to repair them. One great example was I used it to repair cracked speaker cones. It also worked on some of the speakers' surround, but typically had better result if it was a cloth mesh type surround rather than a foam type or a rubber type. After spreading it on a speaker cone crack, just let it dry, and it was quite stiff, but still light weight.
Later, I had a bunch of it mixed up and forgot about it. A week or so later, I remembered. All that was left was this amazingly hard semi-transparent circular block about 5/8" thick. I never had a reason to keep it, but I still have it.
I did notice that some types of foam didn't melt as well as others.
rimar2000 9 years ago
Thanks for the info, MagicTK
That's interesting. Here in the U.S., I got acetone from my local Walmart for 6 dollars over the counter. Why is it so hard to get in Argentina?
kymyst told me that a styrofoam-acetone soluion works as a cement for PVC. I'll have to try it sometime, because that actually sounds useful. :)
kminnie 10 years ago
Effectively, yes. I believe napalm is made with gasoline though.
TrollFaceTheMan 10 years ago
Well technically speaking anything that is a gelled Incendiary... The first Naplam was Actually made up of Naphthenic Acid and Palmitate, hence it's name. But more commonly now napalm is made with petroluem products like Gasoline...
Good instructable BTW!
Oh, that makes sense. Do you know what mechanism a flamethrower emplys to propel it?
Thank you!
http://science.howstuffworks.com/flamethrower3.htm... This does a nice job of explaining it.
liquidhandwash 10 years ago
you should try biodiesel and styrofoam, it completely disappears.
Neat! Where can I get biodiesel? Is there a video showing the process?
I dont know if you can buy bio where you are, you may have to make it
have a look at
http://www.youtube.com/watch?v=TC9h78b2RM4
or google "making biodiesel"
Okay, thanks.
jabrams piechota 10 years ago
The acetone evaporates and the styrofoam mixture can be burned away. No harm done. :)
offramp 10 years ago
I seem to recall reading, many years ago, about a doctor who did something similar with discarded pudding cups and either acetone or tolulene (can't remember which)... he used this mixture to cast prosthetic limbs and was using this method to bring prosthetics to third-world countries.
Cool! Thank you for commenting.
