Acoustic Suspension of Water Droplets
Intro: Acoustic Suspension of Water Droplets
Water drops can be suspended on a liquid surface indefinitely by using acoustic vibrations to prevent the surfaces from merging. I used fairly simple parts for this project. The most expensive item is a stereo amplifier, but they are a common find in resale shops for under $10. I found mine for $6. I used an online tone generator to produce the frequencies which can be found here: http://plasticity.szynalski.com/tone-generator.htm
In this video I ran the speaker at 285 Hz and varied the volume to produce the different effects. There is nothing particularly special about 285 Hz, the drops will stay suspended at other frequencies as well. Any dish soap will also work just as well as another to lower surface tension which increases the stability of the drops.
The 4 inch speaker and 90mm petri dish were both purchased online. Often 90mm petri dishes are labeled and sold as 100mm, which are more common to find. The ones I purchased were also being sold as 100mm, but the actual size could be determined by the reviews. Blunt tip syringes were also purchased online to create the drops.
Be aware that this experiment does involve both water and electricity, so there are potential hazards involved. It should not be attempted unless you are familiar with properly dealing with such hazards.
I first learned of this experiment from slow motion footage recorded by Roberto Zenit, National Autonomous University of Mexico. You can check out his footage here.
21 Comments
Maluvaz 7 years ago
Himers 9 years ago
This is sweeeet!!!
simonero96 9 years ago
https://www.youtube.com/watch?v=kLfV5PeJtUk
NightHawkInLight 9 years ago
I suggest you to try this even with baby oil, frequencies will change a bit but the behaviour of droplets will be much more interesting
maheshs11 9 years ago
Gr8Gr1000Pop 9 years ago
sorry, do not know how to cancel this box
shubham_bhatt 9 years ago
fixfireleo 9 years ago
i've seen this done with, i think, sand instead of water and different waves form different patterns. they used a flat plastic hard smooth surface instead of the petri dish...maybe 8x8 or 10x10?
blinkyblinky 9 years ago
They are called Chladni plates
wobbler 9 years ago
This was fascinating. I noticed that you got a pattern when you got the spontaneous droplets. Did you consider or try putting in two separate tones to see if it generated more complex but regular patterns?
wobbler 9 years ago
Let me know if you do try it, I'd be interested in seeing the results, even if it fails as an elimination is as important as a positive, as I'd find it difficult to set this up where I am.
It could also be interesting to try different shaped containers if this is anything to go by as I'm sure there's a similar effect going on in the water with your experiment, or maybe putting shaped islands in the Petri dish:
This would make a great school science project!
GrumpyOldGoat 9 years ago
I can see the square platform mounted on a gimbal system with a solid pendulum to auto-level the surface and allow for tilting by moving the pendulum in different directions to control the direction of flow of the sand.
A fence around the outside perimeter would contain the sand and help keep momma happy.
omnibot 9 years ago
ccronkhite 9 years ago
There are actually devices based on this that are supposed to keep teens and younger adults out of parks at night. They emit a high frequency tone that cannot be heard by most older people but is quite annoying to anyone who can hear it.
jreauclaire 9 years ago
ShakeTheFuture 9 years ago
FANTASTIC!
Keep up the good work.
JanaMarie 9 years ago
tomatoskins 9 years ago
This is really cool! I love seeing things like this.
