Airsoft RPG
Intro: Airsoft RPG
airsoft rpg great accessory and its cheap and easy if you choose to make one yours may come out different because i made mine like 3 different times due to leeks and other problems. i will make another on how to make a rocket for it.
- about 3ft of 1/2" pvc
- 2 1/2" T connector
- 1 or 2 1/2" end caps
- 1 1/2" ball valve
- 1 1/2" 45 degree angle connector
- 1 to 2 feet of 1 1/2" pvc
- 1 1 1/2" end cap
- rubber tire valve
- pvc cleaner and cement
- saw
- ask the person at the hardware store on how to get from 1/2" to 1 1/2"
- 1 1/2" ball valve
- 1 1 1/2" end cap
- rubber tire valve
- saw
STEP 1:
(Left to right) extra handle for running.............main handle..........trigger (camera made trigger on wrong side its a right handed rpg)........barrel.
Glue in this order or customize to fit you
STEP 2:
you might want to buy an extra end cap for your 1 1/2" pvc for hole size testing
drill a hole in the end cap that should fit and try to pull the tire valve through so its snug might take a few tries
STEP 3:
this is when you ask the guy at the hardware store how to go from 1/2" to 1 1/2" . or find out yourself .
STEP 4:
glue together and add whatever you want for sights and other accessories
let dry
fill her up with a air compressor or with a bike pump
load with mini marshmallows,bbs,or what ever else you want
be safe and have fun
let dry
28 Comments
Masher007 10 years ago
This is not spam, but a warning. PVC will fail suddenly after a while. This was band member that hurt badly by a T-Shirt launcher explosion.
https://fundrazr.com/campaigns/1Zs3c
The Knexer 10 years ago
struckbyanarrow 14 years ago
halogirl 12 years ago
mechaninja 12 years ago
brickman93 14 years ago
silver362 14 years ago
Airsoft_Maniac_96 14 years ago
alex2345 12 years ago
toxicwolf 13 years ago
mad magoo 14 years ago
pyrorower 14 years ago
Airsoft_Maniac_96 15 years ago
ilpug 14 years ago
gx27470 15 years ago
