Airtight Dry Box for 3D Printer Filament
Intro: Airtight Dry Box for 3D Printer Filament
If you have done a bit of 3D printing at home, you probably know from first hand experience that moisture can ruin plastic filament, especially PLA. Over time, moisture in the air is absorbed, and this can cause issues ranging from reduced print quality, to complete print failure. In my case, I hadn't used my printer in several weeks. When I did use it again, the PLA first layer wouldn't stick to anything, it just balled up and got pushed around at the printer head. After weeks of trouble shooting, I bought a new roll of plastic and my printer suddenly worked wonderfully.
This dry box will allow filament to be used and stored over long time periods while remaining moisture free. Additionally it incorporates a filament filter, which will prevent any dust/dirt from entering the printer head, and optionally apply a bit of lubrication for easy successful printing every time.
NOTE: To recondition bad PLA, place a test piece in an oven at the lowest setting. It should get warm but not tacky or overly flexible (best to keep at/under 80 °C). If your oven goes this low, you may place the entire roll of spoiled plastic in there for 2-3 hours to recondition it. Alternately, store your spoiled filament in the dry box we are about to make, and after a week or so it should be properly dry.
STEP 1: Gather Materials
A) Necessary Materials
- Storage Tote (Must be large enough to fit filament spools, minimum dimensions of 10 inches (260mm) was my requirement, that should fit spools larger than shown). Also available from Amazon but only as a 6-pack or at a very unreasonable price.
- Rod for spindle (~8mm x tote length), I had a piece of threaded rod left over from my RepRap build
- Super glue and (optionally) super glue accelerator
- Push-to-fit tube connectors for 3mm filament OR for 1.75mm filement
- Small pieces of foam
- PTFE tubing for 3mm filament OR for 1.75mm filament
B) Tools
- Power drill and bit set
C) 3D Printed Parts - These can also be found on my Thingiverse page
- Spindle Rod Holder (x2)
- Feedthrough A (Exterior)
- Feedthrough B (Interior)
STEP 2: Make the Lid Airtight
Use 4 pieces of rubber tape to make a seal along the inner rim of the storage tote lid, overlapping the corners. First test fit a piece, cut it to size then apply to the lid. Note that this type of rubber tape is not especially sticky, except to itself. So after placement on the lid the tape can be repositioned, but when overlapping tape corners, it will be a bit more difficult to undo so try to make sure it fits well when overlapping the corners.
STEP 3: Attach Rod Holders
Test fit the spindle rod with a spool of plastic filament on it to get the height correct. Take a piece of sandpaper and scuff the side of the box where the rod holder will be glued. Spread super glue on the back of the 3D printed rod holder. Press it onto the sanded spot on the tote. By looking from the other side of the tote (if yours is clear) you should be able to see how well the super glue is adhering, press to get as complete of coverage as possible.
You can apply the accelerant if you wish, but either way I recommend letting the glue dry for several hours, even better if it can dry overnight. Air and moisture need time to diffuse into the space between the two plastics in order to cure the superglue.
Next put the rod in the one holder that is attached, and align the rod so it is level to the other side. Repeat the sanding and attachment process for the other 3D printed rod holder. Once this is fully dry you can put the filament spools on the rod and place the rod in the holders.
STEP 4: Prepare the 3D Printed Feedthroughs
Screw in the push-to-connect fitting to the 3D printed feedthrough. It is designed to be a snug fit, so it may help to warm the female plastic side slightly (with a lighter for example) before screwing the threads in. Make sure to keep the fitting aligned and straight. Test fit that is it straight by inserting a piece of filament through it.
Now cut a piece of foam to fit in the recessed part of the other filament feedthrough half as shown. Poke a small hole in the center to allow the filament to move through it. Test fit a piece of filament as shown.
STEP 5: Add Filament Feedthroughs
Drill a hole a few inches from the top of the tote with a drill bit of slightly larger diameter than your filament. Test fit the filament and lightly sand both sides of the box wall for better glue adhesion.
Now apply glue to the faces of the 3D printed feedthrough parts. Be sure to keep some distance between the glue and the feedthrough hole and especially from the foam, which will soak up glue on contact. Center the pieces on the hole you drilled in the tote and firmly press the pieces on, with the tube fitting facing outwards and the foam sealed against the tote on the inside, with the access hole to the foam facing up. While the glue is still wet, you can test fit a piece of filament to make sure all of the holes are aligned. Be sure to move the filament in and out so the glue does not bond it in place if it does come in contact.
Again, accelerant may be added at this time. Be sure to let the superglue dry thoroughly. Overnight drying is recommended.
Repeat these steps for as many ACTIVE filament spools as you will need, usually 1 is enough but if you have a dual extruder set up you will need a second. Another option is to give each spool a feedthrough, then glue a second exterior only feedthrough near the bottom of the tote. Then when a spool is not in use you can plug that PTFE tube into the lower push-to-fit connection on the tote. This will make changing filaments quick and easy if you change them frequently, while keeping the dry box sealed.
STEP 6: Prepare for Use
Add the PTFE tube to the push-to-fit connectors. These are typically used for Bowden type extruders, which I plan to add to my printer soon, but I will use the tube to guide the filament for now anyway. Feed the filament through the hole in the tote box and into your extruder.
Optionally, add a few drops of oil to the piece of foam within the feedthrough fittings. Some people suggest mineral oil, or vegetable oil. This will serve to further lubricate the filament as it travels through the PTFE tubing and into the extruder. I don't find it necessary for now, maybe in the future or with filaments other than PLA.
Add at least two packets of silica gel at this time. Add the lid and close it up. You are now ready to print with your moisture free filament!
16 Comments
2092645 1 year ago
mcfada 1 year ago
MikeI32 7 years ago
Something you can do to at least partially restore hydrated filaments is to bake them in the oven at 180F (NOT 180C !!!) for about 2 hours. I've done this with 1.75 ABS that was "shrinking" and PLA that wasn't sticking on the first layer, both were improved quite a bit.
Having said all that, I still plan to make an "active dry box" when I get some time. Right now, I'm storing filaments in an ordinary sealing box with a silica gel pack and humidity meter, being able to access all the stored filaments and build with them without opening the box will be a huge win. Thanks for posting this guide.
gadjetramjet 7 years ago
You might want to look up "Orange Silica Desiccant" It is a "indicating silica that changes colour when saturated (and can generally be refreshed by warming). Another product of interest is items used to dry compressed air for painting etc. available at auto parts store, or the air dryers used to store recreational vehicle, it uses a "holder" and a chemical to absorb moisture that then settles to the bottom for disposal, it can keep a whole camper or boat interior moisture free, in a box it should be great for a long time. There are also "cards" available with dots that change colour when a certain level of humidity is reached, the cards come in various levels, these could be used as indicators to know when your filament has been exposed or has got to much moisture.
DylanD581 8 years ago
Great 3D printer filament storage box. Have you considered adding tubing and holes for each filament, thus allowing for quick changeover?
mcfada 8 years ago
Hi, thanks for the comment. I certainly have considered this. I don't have the push-to-connect fittings as last time I checked amazon would only ship them as an add-on item, but in the future I plan to have 4 tubes running out as the one shown in the intractable, one for each spool. Further, I plan to add another push-to-connect fitting 8-10 inches below each one (without a through hole though), so that each tube can be secured when not in use in order to keep things neat and also effectively airtight. Perhaps I will provide an update to this once that is done.
fred_dot_u 8 years ago
Target (USA) sells Sterilite brand air-tight bins, 54 qt size, with a silicone rubber seal on the lid and four clips to hold the cover closed. I'll be making good use of your instructions as soon as the other parts arrive.
thanks!
mcfada 8 years ago
Good to know, I didn't see those when I bought my tote at Target. Good luck on your build.
Cloudfantasy 8 years ago
Great instructable, will make it one day :)
mcfada 8 years ago
Thank you!
NorthPalmBeachFLLocksmith 8 years ago
Naturally
wire-nut 8 years ago
In plastics industry it normal to dry material before using it. I still remember when first using it, drying it do to cut out brittleness.
tabris25 8 years ago
Genius! I was wondering how to keep the filament dry in a classroom that has fish tanks in it. This is so simple.
mcfada 8 years ago
Thank you! Let me know if you have any questions while making it. I cannot express enough the added benefits of the PTFE tube to guide the filament to the extruder drive as well. And don't forget to let the glue dry thoroughly, it's easy to get impatient, but superglue does make a strong bond and I've been printing almost non-stop since building this. Good luck.
micahmezaene 8 years ago
Great work !
mcfada 8 years ago
Thank you!
