Another Cheap Easy Desk -- 1 Sheet of Plywood and 1 2x3 (or 2x4)
Intro: Another Cheap Easy Desk -- 1 Sheet of Plywood and 1 2x3 (or 2x4)
I needed a smallish desk for a space in my bedroom to last the 8 months or so until I move. I could have done this better, and made it more long lasting, if I'd used 1 1/8" plywood instead of 1/2" MDF, but it's good enough.
STEP 1: I Needed a Desk...
It was raining out, and my garage is so messy that I dare not photograph it, so I didn't build this out of a single sheet of plywood and a 2x4, but I could have. Instead I used a 2x3 that I had in the garage and 4 precut sheets or 2'x4' MDF at 1/2" thick. I needed a desk for the bedroom, because I was tired of not having one. I also wanted it to be something that I wouldn't mind throwing away in 8 months when I move 2500 miles or so, since it's crazy expensive to transport heavy/large things that far.
STEP 2: Sorting Out the Legs
I measured for a desk surface 31" from the ground (most people will want 30", but I like being different.
STEP 3: Putting It All Together
Then, with my wife's help, I glued and screwed the "back" into the "top" and then the "legs" to the back/top assembly. Then I took the 2x3 and screwed it in at the back across the bottom, to keep it together while it's moved, and one across the middle under the desktop, to keep it from flexing. These might not be necessary if you used better joinery and thicker stock. If I were doing this to keep, I'd have used 1 1/8" birch plywood and only needed the one on the bottom.
STEP 4: "finish" Work
I should have used my old standby for wall mounting and use a piece of baseboard molding screwed into the vesa mounts on the monitor and screwed into the back, but instead I used a mounting arm that I had left over from something else to mount the 22" LCD I got for $150 from Best Buy on Black Friday and then I put the rest of the computer stuff into place. I'm going to buy a KVM later tonight to hook up my laptop to the big screen/keyboard/etc also.
It took more time for me to find where I put the box of screws than it did to assemble, and cost $25 for the desk (I'm not counting the LCD mount, because I'd not have bought that if I didn't already have it, and it could have been mounted cheaper. I did specifically mount the back like that so that I wouldn't have to make any holes in the wall to hang the LCD. I'll probably get something I can use as a whiteboard for the back and sides, because I really like whiteboards.
13 Comments
pRavi89 11 years ago
uberwald 16 years ago
lofgren 12 years ago
Can I make a couple of suggestions for your final version?
-Yep, drill holes for cables.
-Replace the lamp with LED back lighting behind the edges of your monitor - you are an IT guy after all! :) (wasn't so readily available in 2008)
-To strengthen the front of the desk and prevent bowing, add a strip of wood for support underneath the front and or a facing piece (which will make it look more substantial/expensive too). Incidentally, if you use plywood, facing pieces and hide the sandwich layers and give it a more professional look.
-If you like the look (it is a bit old school), maybe cut the sides on a diagonal, sloping from the top of the back down to the desk at the front. Install a hatchback-style lid with appropriate hinges and latches to keep it open, which hides your gear and or could be a drafting table when closed.. ;)
Keep up the good work ;)
DemonGal711 14 years ago
sysadmn 16 years ago
gamer 16 years ago
Shifrin 16 years ago
zomfibame 16 years ago
GorillazMiko 16 years ago
