Arduino Segway
Intro: Arduino Segway
Hello!
More than 3 years ago I started to tinker a homemade segway. Though it's still not really finished (I have to replace the 250W Motors by 500W-models) my children are able to drive around.
If you're going to build one you will Need the following parts:
* wheelset: In my case I use 12 1/2 x 2.75 tires usually taken for dirt bikes (f.e. www.amazon.de/HMParts-REIFEN-MIT-SCHLAUCH-12/dp/B0038X9ODA; http://www.ebay.com/itm/Tire-Rear-Wheel-Mini-Pocket-Dirt-Bike-47cc-49cc-50cc-COOLSTER-QG-50-RX1-Traxxis-/182346539856?hash=item2a74b36350:g:BxUAAOSwh6xTtmwX&vxp=mtr)
* batteries: I use two 12V/12Ah lead accumulators to get 24V for the Motors
* Motors: At the moment two 24V/250W models but the 500W-motors are already waiting for their use
* for the axle I asked a local welder and some of my bicycle-parts (bar, stem) fit perfect too.
STEP 1: The Motor Driver
First I tried a homemade full-bridge. To control it I used the analog-out (pwm) of the arduino. But with this variant I didn't succeed. Therefore I bought a commercial product, a 2x60A Motor Driver from sabertooth (www.dimensionengineering.com/products/sabertooth2x60).
The arduino is able to communicate with the sabertooth via a simplified serial code.
STEP 2: The Angle Determination
To determinate the current angle I first used a separate accelerometer (ADXL335) and gyroscope (LY530AL). Last week I changed this Setup and the two boards have been replaced by the MPU6050.sensor, which combines the two elements.
The advantage of the gyroscope is, that accelerations don't influence the measurements. The disadvantage is, that the gyro has a drift and after a while the angle goes higher and higher.
The Advantage of the accelerometer is, that it doesn't show any drift like the gyro. But it's being influenced by accelerations, which change the Output.
A filter combines both pro's so the calculated angle is near the real value. This filter can be a simple complementary-filter (like in the Picture) or the more complicated kalman-filter. The Input of the kalman-filter is the actual angle measured by the accelerometer, the angular Speed measured by the gyroscope and the time-step between two measurements. With these Parameters the kalman-filter is able to calculate an angle, which follows the gyro in times of high accelerations and in times of less accelerations it approaches the value of the accelerometer. In the Picture you can see the drift of the gyro and the good Job of the filter.
STEP 3: The PID-controller
The segway tries to get the angle down to 0°. If the angle is positive, the segway brakes or accelerates backwards. If it's negative the segway accelerates forward.
But which signal get the motors? This is exactly the task of the pid-Controller.
The proportional-part: The angle should be 0°. So the greater the angle, the higher the speed of the motors.
Mathematically you can write:
angle_error = angle_should - angle_is
p-Motor-value = k_p * angle_error
The integral-part: When the current angle isn't zero, the Controller tries to get the segway horizontally again. But this approach shouldn't be slow and the smaller the angle-values, the slower the changes. Therefore the Controller allows a faster approach with the disadvantage, that the movement doesn't stop at 0° and goes a bit to the other side. This behaviour is guaranteed by the integral-part. All the angles are added (integrated) and this integral over time should be Zero. So if the angle is f.e. positive for a while, the Controller tries to get the seqway into the negative area. This guaranteeds faster approaches...
error_sum_new = error_sum_old + error
i-motor-value = k_i * (error_sum_new)
error_sum_old = error_sum_new
The derivative-part: Not just the current angle is important but also the changes of the angle. Let me explain: If the angle is f.e. 10° and it doesn't Change a lot, the Motors don't need to correct this shift very fast. But if the angle is 10° and it changes very fast (high derivative), than the motors have to correct this also very fast.
d-motor-value = k_d * angular Speed
Finally you get: motor-value = p-motor-value + i-motor-value + d-motor-value
STEP 4: The Complete Setup
Now it's time to start the segway. To drive not only straight ahead you have to mount two buttons. When you push f.e. the right one, the left Motor increases Speed and the right Motor slows down. To ensure smooth transitions the added and deducted value starts at zero and increases step by step (+0.5 every loop) until he reaches the maximum value (f.e. 30).
To try out your own segway I 've attached the simple program for you. Good luck and don't follow the segway-inventor James Heselden down a cliff ;-)
Maybe you want to take a look at my YouTube-channel: www.youtube.com/user/stopperl16/Videos
more physics projects: https://stoppi-homemade-physics.de/
41 Comments
dawnmonmonwin 2 months ago
မဂ်လာပါ။အရမ်းကိုကာင်းမွန်ပါတယ်။ ကျွန်တာ်လည်းကြိုးစားပီးပြုလုပ်ကြည့်ပါ့မယ်။ကျေးဇူးတင်ပါတယ်။
SamM292 2 years ago
quanhung19876 3 years ago
darthfader64 3 years ago
drlexluthor 3 years ago
Jinu Jogy 5 years ago
Is it possible to use this H bridge instead of sabertooth dual 60A motor driver, since its too expensive, so I cant afford it. If not can you suggest me a good one at lower price range?
Coskunkodr 4 years ago
Coskunkodr@gmail.com
stoppi71 7 years ago
Yes, you'll need a second button (voltage-divider with the 10 kOhm-resistor)... Pin 12 and 13 are low, if the button isn't pushed. If you push the button for steering, the signal goes high...
Therefore I ask in the program: if (steering-button-right or left) = high then ...
I've changed the Picture of the circuit, because in the first version the status was low if the button was pressed ;-)
meghabhosale1503 5 years ago
Can i get full pdf of segways construction
YashS142 5 years ago
i m using 2 350 watt motors for segway.i have two 12 volt batteries that connect in series giving 24 volts.i want 14 amps current for each motor. how can i get that? what possible combination capacity of battery (voltage and current) should i use? i m using sebertooth motor driver 30*2 channels.please guide me for motor driver function and how i couple motors with wheels
YOSHIMINE 6 years ago
Your research is very good
I am a teacher of an industrial high school in Japan.
I have a request
I referred to ”Step 4: The Complete Setup”, but the motor does not work.
”FXLSYHKIW6PNEU6.ino” could also be compiled.
I'm sorry.I still need to study more.
It would be greatly appreciated if you could explain the details.
AirraB 6 years ago
Can i use another motor driver? i would like to use your project as reference in my project but the driver that you used is not available in our country and the cost was too high heheh... can you give me some advice about the motor driver? thanks ^_^
sonasec 6 years ago
thank you for sharing, you have making the best project for me ..you're actually a professional engineer.!
pachanoid 6 years ago
very good, am making a robot with that code, and its working!
HippieC 7 years ago
Way too advanced for me but i know some people in stockholm that made one at maker space. Was very impressed!
KonstantinL8 7 years ago
Cool project and nicely documented!
How much weight does the current setup (250W motors) carry around?
and do you have some kind of encoders or odometry for the wheels?
SherylinRM 7 years ago
You definately have my vote.
Thanks for this :)
I've to thank ;-)
