How to Connect Arduino and RFID
Intro: How to Connect Arduino and RFID
On this instructable I will try to show how to interface a RFID sensor with the Arduino. I am using the RFID sensor from seeedstudio the serial version of it. There are a few parts you will gonna need. I also bought some RFID keys.
UPDATE: Now it works with IDE 021
STEP 1: What You Gonna Need?
- Arduino Board
- RFID Sensor from seeedstudios
- Wires
- Protoboard
- RFID tags (125kHz) from seeedstudios
- Wires
- Protoboard
STEP 2: Plugging All Together
Connect the antenna on the appropriate pins like the first photo.
Plug the RFID sensor to the protoboard like the second photo above.
Only 3 wires are required to interface, 2 wires for supply and another for the serial line(communication)
The wires as connected as the third photo shows.
On RFID sensor: PIN 1 -> Tx
PIN 2 -> Rx (Not Used)
PIN 3 -> NC
PIN 4 -> GND
PIN 5 -> VCC (+5V)
Tx from RFID board goes to Digital PIN 2 on Arduino Board.
That is all you gonna need to wire.
Moving on to next step, the software.
PIN 3 -> NC
PIN 4 -> GND
PIN 5 -> VCC (+5V)
STEP 3: The Code
I'm not a software guy, so this code is just for demonstration.
I don't make any kind of checksum at the tags code, but it seems to work fine.
The code is really simple. I used a new library for the serial, using software emulation.
With the two white cards you can deny or allow the access of others keys.
Any doubt, please ask me.
Edit (05/11/12):
code update for new Arduino version
Edit (05/11/12):
STEP 4: Results!
There is no LED, sound or LCD for debug or visualization, just through the serial line.
The video demonstrate how to use the software. I didn't post any kind of explanation as text on the video. I hope that the images spokes more then words, xD
Any doubt or suggestion, feel free to ask, or correct me.
Please, if you like it, rate it,
thank you
thank you
184 Comments
epidemicz 14 years ago
otaviousp 14 years ago
GiovanniC84 5 years ago
nugax1 5 years ago
Attached find my version which does what it should do.
## Modified code to work with Arduino 1.0.1 / ##
## Credits to Petushka, https://www.instructables.com/member/Petushka/ ##
## https://cdn.instructables.com/ORIG/FM4/KU9W/H91LGBA6/FM4KU9WH91LGBA6.txt
#include <SoftwareSerial.h>
#define ADD_TAG_CODE "bfbdbfa57de717a0" //change this ID with your own card TAG (2)
#define DEL_TAG_CODE "bfbdbfa5899d5420" //change this ID with your own card TAG (1)
SoftwareSerial rfid = SoftwareSerial(2, 3,true);
String msg;
String ID ; //string to store allowed cards
void setup()
Serial.begin(9600);
Serial.println("Serial Ready");
rfid.begin(9600);
Serial.println("RFID Ready");
char c;
int i;
void loop(){
while(rfid.available()>0){
i=rfid.read();
msg += String(i,HEX);
Serial.print(i,HEX);
Serial.print(" - ");
Serial.println(msg.length());
// msg=msg.substring(0,15);
if(msg.indexOf(ADD_TAG_CODE)>=0) add();
else if(msg.indexOf(DEL_TAG_CODE)>=0) del();
else if(msg.length()>10) verifica();
msg="";
}// Ende von Loop ----------------------------------------------------------------------------
void add(){
Serial.print("What TAG do you wanna grant access?: ");
msg="";
while(msg.length()<16){
i=rfid.read();
if(ID.indexOf(msg)>=0) {
Serial.println("\nAccess already granted for this card.");
msg="";
else{
Serial.print("Card: ");
Serial.println(msg);
ID += msg;
ID += ",";
//Serial.print("ID: ");
// Serial.println(ID);
msg="";
Serial.println("Access granted for this card.");
void del(){
msg="";
Serial.print("What TAG do you wanna deny access?: ");
i=rfid.read();
if(ID.indexOf(msg)>=0){
Serial.println("TAG found. Access for this card denied.");
//ID.replace(card,"");
int pos=ID.indexOf(msg);
msg="";
msg += ID.substring(0,pos);
msg += ID.substring(pos+15,ID.length());
ID="";
ID += msg;
//Serial.println(ID);
} else Serial.println("\nTAG not found or already denied");
msg="";
void verifica(){
if(ID.indexOf(msg)>=0) Serial.println("Access granted.");
else Serial.println("Access denied.");
SolomonB21 5 years ago
How to increase the range upto 30 cm?
By increasing the coil loop of antenna can the range be increased?.. Instead of reading.. Just detecting the presence of rfid tag is possible right?.. Kindly answer my doubts. Thank you
John_03 5 years ago
Hello and Thank you for the post.
I have in serial output this:
4
8600
5
86008
6
860088
7
8600887
8
8600887B
9
8600887B5
10
8600887B53
11
8600887B53&
12
8600887B53&
13
TrầnÂ19 6 years ago
i connected module to arduino promini with your code but i can see my tag code in serial monitor.
can you help me ?
thanks.
greatescapeprops 6 years ago
Thanks for the tutorial. I have it all working but the cards do not read fast enough or not at all. I have to put the cards directly on the antenna. Any ideas on this? I have all 125Mhz cards with the correct reader and hookup is correct. Thanks.
Gregory Akau 7 years ago
ShoaibH3 7 years ago
plz send me rfid code at this shoaibhassan031439@gmail.com
i need it urrgent...plz
sweeth 7 years ago
Hi, This is really nice. Can we calculate distance also? if in case we would like to calculate distance as how much far or close the tag is with reader , is that possible?
Regard's
Hari
otaviousp 7 years ago
sweeth 7 years ago
Hi, Thanks for the kind response,
Can we measure distance via signal strength? Or can you please suggest me any other module? I have MLX 90109 with DVK 90109 and EVB 90109
lef11 7 years ago
I had the readers and they dont seem to be reading i have them hooked up the way you have it set up but how does your code work? there arent any comments throughout the code and i have been looking to use them for a school project. can you help?
lef11 7 years ago
AroojZ 10 years ago
F-sidd142 7 years ago
i have the same problem. please tell if someone have sorted out.
MandeepS1 9 years ago
Have your been able to figure it out pl, I have the same question
