Automatic LED Night Light (Using 555 Timer)
Intro: Automatic LED Night Light (Using 555 Timer)
And you finding your torch in the DARK !!! Ohh...
No worry, here is the automatic dark detected led light.
STEP 1: Parts You Need
* 1K resistor
* 10 resistor
* LDR (light dependant resistor)
* Red led (2ma)
* 1W white led
* BC338 transistor
* 555 timer IC
* DC socket
Note: Use dc socket according to your charger/adapter pin.
STEP 2: Circuit Diagram
The circuit uses main IC called 555 timer ic as it basically used in ustable and monostable modes.
The circuit is very simple to build across IC 555
Red led is provided as a Standby indicator which makes you know LDR is detecting light.
And as the darkness in the room get increased above certain limit, red led shuts off and 1W led is swiched on by transistor.
Here I have used 1M ohm resistor. You can adjust this resistance from pin 2/6 of the ic to ground(-) in order to adjust sensitivity to darkness.Less the value of the resistor, more the sensitive in dark.
20 Comments
riz_zu 7 years ago
plz give me detail explanation of this circuit
Jayesh Jayesh 6 years ago
u can make this using any flip-flop to !
yijaz 7 years ago
CharlesM184 7 years ago
since all LDRs have different resistances change the 1 meg resistor accordingly.
Amukim 8 years ago
Jayesh Jayesh 7 years ago
Hey I uploaded diagram with auto switch.
Just checkout !!
Amukim 7 years ago
HarikrishnanN 8 years ago
Good
Interesting
But father and mother wont give money to do this
Then also you can make it only in 1Dollar !!!!!!!
RoshA 8 years ago
Hi, what do you call that switch?
Three way switch .
Just checkout the new diagram I uploaded !!
ddani1 8 years ago
Nice Project but having problem while making, Please Elaborate 1M ohm resister working and how we calculate the appropriate register value instead of 1M ohm
Jayesh Jayesh 8 years ago
By increasing value to 1M, you making it less sensitive to DARK.
And reducing under 1M will make it more sensitive to DARK !!!
SayeedS1 8 years ago
OR
simply you can charge with any 6V adapter ,if 1A then for an hour.
ddani1 8 years ago
thanks
Omnivent 8 years ago
Hi,
In one of your photos, the switch is marked "Auto - Off - ON" and right below it, you have written "Mode - On 70mA - Auto 170mA - Standby 2mA".
You didn't mention how you wired it?
Nor did you explain the current draw in each position - I'd rather think of numbers like "Off 0mA - Auto Standby ~0.5mA - Auto On 400mA" and I can only guess on the ON current, as you didn't show how you wired it.
A 1W LED with a 3.6V drop, should never see above 278mA!
It seems like you use a 4V (2 cell) lead acid battery, so it will be around 4.2V when fully charged and 3.8V when flat. The Auto On current will vary in this interval from around 200mA to 400mA (if the LED has got a 3.6V drop, higher if the LED drop is say 3.3V)
You really ought to have, (at least) a current limiting resistor on the LED! As is, the current is determined by 3 variables; LED voltage drop, Supply Voltage and the current gain of the transistor. The LM555 really should have a higher voltage - 4V is stretching it.
If you raise it to 5V (or more), you'll be able to use a simple current limiter (attached pic), that is relatively unaffected by varying voltage or the LED's voltage drop.
I have not mentioned about it, because is i have added for my purpose (to manually ON/OFF leds at lower current drawn around 70ma)
Here 1W led no need current limiting resistor.As the full charged battery have 4.2V on it and transistor drops 0.5V. So, 3.7V max is fine for this led.
BeachsideHank 8 years ago
Good work, I like your enclosure, simple but effective (the most important part).
