Automatic Water-Tank Motor Controller
Intro: Automatic Water-Tank Motor Controller
You can see the working of this controller explained in the lovely diagram...
Its a simple controller, which would help to turn the water pump on, when your water tank is empty, and will turn it off when the tank gets full, and will keep it turned off until the tank is empty...
STEP 1: Working
The lower sensors acts as the 'J' input and the upper sensor acts as the 'K' input in the J-K flipflop...
the working of both the sensors is opposite, i.e. the upper sensor gives output 1 when the water is detected, and the lower sensor gives output 0 when the water is detected...
With this kinda sensing, we can predict the JK flipflop's output as-
when there is water on both sensors, input = 0 1, output = 0 = motor off
when water is coming down after filling up, input = 0 0, output = 0 = motor off
when water comes below the lower sensor, input = 1 0, output = 1 = motor on
when water starts rising from the lower sensor, input = 0 0, output = 1 = motor on
STEP 2: The Circuit
The circuit works on 12v dc power supply, which you can give from a 12v DC adapter...
The circuit is built around 3 main ICs-
LM358 - dual comparator - sensing IC
NE555 - timer ic - clock pulse generator
7473 - JK flipflop - the controller/brain
You can see the components and the connections as per given in the circuit...
The components you will need to build this circuit are -
-12v dc jack female
-1x(100uf or 200uf or 500uf or 1000uf) + 1x10uf capacitor
-7805 volt regulator + heat sink
-2x 500k potentiometer
-2x 47k ohm resistor + 2x 470 ohm resistor +1x 330 ohm + 1x 270 ohm + 1x 100ohm + 2x 10k ohm resistor
-LM358 IC + base
-LM555 IC+base
-7473 IC + base
-1x diode
-12v relay = heavy duty according to motor
-2x red led + 1x green led + 1x yellow led
-1x BC547 transistor
-12cmx12cm prefboard
-12v DC adopter
correction - the pin 2 and 6 are connected in the 555 IC in the circuit.
also do connect the Vcc and Ground of all the ICs, you will easily get the pin configuration of the ICs on google...
48 Comments
tripathi_kush22 6 years ago
MayankA43 6 years ago
Please tell a solution for it.
Samartist 6 years ago
here is the solution, you can add an AND gate and an extra water level sensor module to implement that functionality....
hari yamadri 6 years ago
rana wasala 7 years ago
SangeethaR4 7 years ago
I am planning to try this circuit and wanted to know what kind of sensor need to be used with this circuit?
Thanks!
djfreestyle80 7 years ago
I want to try this..but may I know what LED do when running sir..? do they flip-flop when relay start pump "On" or else..coz i'm beginner here..thanx for information:-)
DJAdnanMalik 7 years ago
nice circuit.
i need little help. actually we have utilitiy water supply problem in my area. there is no timing of water supply. so i want a circuit to start my pump after every 30 minutes if water comes the motor continue to run if water not come motor stop after 1 or 2 minute. any body plz help me
Thanks
johnip4 8 years ago
They won't get dirty and will also work with fluids other than water.
anoop mu 9 years ago
Samartist 8 years ago
you need to give +ve and -ve voltage of every IC
and pin 2 and 6 of IC 555 are connected...
Samartist 9 years ago
this circuit is fine, recheck your circuit
if you are still unable to debug it, then upload the pics of your circuit... i will see them...
alaam2005 8 years ago
thanks for sharing. I think the circuit diagram shows using the first half flip flop while you used the second half, isn't it?
Harry777 8 years ago
Nandup1 8 years ago
Could you tell me its cost.. ??
