Balancing Robot
Intro: Balancing Robot
This is a very simple robot that uses a simple switch as a sensor and stands on only two wheels with inverted pendulum mechanism.
When the robot is going to fall the motor starts and moves the robot to the direction it is going to fall, so the motor torque about the center of gravity that is higher than the motor makes the robot balanced.
STEP 1: Things You Need
To make this robot you need following parts and tools:
small electric motor
some gears
(or a motor with gearbox)
a shaft
two wheels
some sheets of plastic to make bearings and the robot neck
two battery holders
4 AA batteries
one button cell
one SPDT (single pole double throw) switch with a metal lever
one toggle switch for the on/off switchs
one nail
some wire
soldering iron
some glue
some gears
a shaft
two wheels
two battery holders
4 AA batteries
one button cell
one nail
some wire
soldering iron
some glue
STEP 2: Motor, Grears, Shaft, and Wheels
In this step you must make a system to moves the robot you can make it easily by adding some gears to a simple small motor, then connect it to a shaft and assemble it two wheels.
You can also use a motor and gearbox.
It does not matter how you make it.
STEP 3: Attach Robot Neck and Head
Use glue to attach a sheet of plastic to the motor.
Then put some glue on one side of battery holders and attach them to the top of the plastic sheet.
STEP 4: Making the Sensor
Solder a button cell to the SPDT switch lever.
Make the nail head hot on a flame and put it on the plastic sheet on the motor in a position that when the robot stands vertically the button cell touches the ground.
Then attach the switch to the robot with glue.
STEP 5: Connecting the Switch
Solder a wire form positive pole of one of battery holders to the negative pole of the other battery holder and attach the toggle switch to it.
Then attach the other side of the switch to the motor.
STEP 6: Wiring
Now it is time to solder the robot wires.
Note that you must solder the wires in a way that robot moves to the direction that is going to fall.
STEP 7: Testing
The robot is now completed and it is time to test it.
Put 4 batteries into the battery holders and turn on the switch.
Try to change the position of the sensor to make the robot works better.
If the robot works inverted swap the red and blue wires on the sensor or on the battery holders.
235 Comments
tcheupluk 6 years ago
waw with a nothing you amaze us.
waw avec un rien vous nous épatez.
aazzaki 8 years ago
vahidyou 8 years ago
Look at step 6.
crafty squid 8 years ago
interesting
COOL
jpedroc 8 years ago
This is VERY VERY WITTY. Very simple way to create a self balancing robot.
I saw... I could say, the opposite robot, a very stable two wheels robot here (it is open source): http://jjrobots.com/b-robot/ This robot uses stepper motors instead.
bolanka 8 years ago
Thanks.. I made it.
Arthak 9 years ago
vahidyou 9 years ago
Arthak 9 years ago
maker_studio 9 years ago
The easiest Arduino UNO based self-balancing robot, controllable by Smart Phone, RC and more!
https://www.indiegogo.com/projects/balanbot-best-arduino-self-balancing-robot-ever/x/8897587#home
ERockDesigns 14 years ago
dratman 10 years ago
vahidyou 14 years ago
High CG object has high moment of inertia, so it needs more moment to move and has more stabillity. Because of these you must choose the longest robot and consider your motor power.
The more complex controlling system, the more stabillity. but the most important feature of this robot is that it is simple (according to the the others comments)
jestela 10 years ago
vahidyou 10 years ago
wcallag 10 years ago
nmvb 11 years ago
