Bearing From Aluminum Beverage Cans
Intro: Bearing From Aluminum Beverage Cans
Bearings are what make the world go around. This project makes a simple bearing form a couple off empty aluminium beverage cans.
A couple of uses for the bearing are as a turnstyle - useful when painting small objects and to rotate visually deceptive artwork.
STEP 1: Cut Two Cans Bottoms
Cut the base off two aluminium beverage cans. Trim along the edges to make smooth with a pair of scissors.
STEP 2: Making Ball Bearings
To make the ball bearing, screw up some aluminium foil into a small ball. Compress the ball with your fingers. After making 10 balls, round and compressed some more by placing them under a piece of plywood and moving the ply around, while applying some downward pressure.
STEP 3: Complete the Ball Bearings
Place 10 completed aluminium balls in one of the bases. Turn the other beverage can end upside down and place on top. Turn it around to ensure it pivots freely.
STEP 4: Find the Centre
Find the center by sliding a pen placed on a suitably sized book across the outside of the base. Do this four ways to create a small square. Mark a couple of diagonals across the square to locate the center.
STEP 5: Attach a Bolt
Drill a center hole, then enlarge it to be a 1/4 inch hole.
Fit a suitably sized 1/4 inch bolt into the hole to secure the 2 sides of the bearing together.
STEP 6: Uses: Turning Artwork
So, what can the bearing be used for? I used it to turn some eye-catching artwork around 180 degrees.
STEP 7: Turnstyle for Painting Objects
Another use is as a turnstyle for painting small objects, this allow the object to be rotated as it's been painted.
5 Comments
LADY DIXIE T 7 months ago
WWHverring 8 months ago
Brucesmith50 8 months ago
Also good to see how simple, home style fabrication can be used to solve real issues - no 3D printer or CNC machining required (not to denigrate either, but it’s nice to see simpler solutions too).
I salute you!
MarkH342 8 months ago
Tom Hargrave 8 months ago
