Beekeeping Honey Extracting Field Cart
Intro: Beekeeping Honey Extracting Field Cart
This instructable is for building a cart to hold a 2 frame honey extracting barrel, 5 gallon honey bucket with strainer.
And a metal bucket to hold the capped wax.
This came about last year when i harvested honey, and dragged all the frames back to the garage to uncap them this as messy and labor intensive. So i needed something that could secure the extracting barrel when spinning the frames. And that i could drag it to the hives and extract the honey at the hives this should be easier on both me and the bee's.
STEP 1: Stuff You Will Need
Wood
paint
nail's
bungee cord
honey extractor 5 gallon bucket
honey strainer
wire mesh
tape
A U Bolt
TOOLS
Saw
drill
painting stuff
paint
nail's
bungee cord
honey strainer
wire mesh
tape
A U Bolt
TOOLS
Saw
drill
painting stuff
STEP 2: Step One: Build the Base
I didnt measure anything here, so i cant give you lengths. i just built this around the size of the buckets.
So i built a rectangle out of 2 x 4. Then cover half with some ply wood, (all of this wood was from a floor i tore out)
STEP 3: Step Two: Build the Vertical Support
Now build a second 2 x 4 box and make a T with it on the other and nail the whole thing into place.
STEP 4: Step Three: Build the Second Level
Now you have your vertical support nail some 2 x 4 on each side and another plywood shelf on top of that, make sure that it hangs over half the bucket and is tall enough for the bucket with strainer to sit under.
STEP 5: Step Four: Second Level Add On's
I added two things to the top of this some boards on the sides to hold the extracting bucket into place. And a couple of plywood strips on the back, this is two hold the bucket at a slant so the honey can pour into the bottom bucket faster.
Now dot where the U bolt will fit over and secure the pour spout on the extracting bucket and drill those holes.
STEP 6: Step Five: Painting
i slapped on a coat of white paint i had around to make it easier to keep clean.
STEP 7: Step Six: Field Proofing the Cart
OK now the paints dry, i secure the extracting bucket with the U bolt. Tape the honey strainer to the top of the bucket. Make sure the only way into the bucket is through the strainer.
And bungee cord the bottom bucket into place, and now take some mesh and tape it around the bucket and the our spout. Make sure no bees can fly in and get stuck in the honey.
Add your bee tools and a metal bucket for holding the capped wax and and a bread knife, and the rest of your bees stuff.
NOW FOR THE WHEELS........ crap i don't have anything to use for wheels so i will have to add them on later and use a wheel borrow.
ok now i can uncap and extract the honey and wax at the hives saving alot of time and effort.
8 Comments
Jobar007 12 years ago
LoganMackey 12 years ago
gdsmit1 8 years ago
I did crush and strain for my first year. The big problem is it takes the bees a lot of honey to replace the wax that you destroy.
The next year I borrowed an extractor and it moved much smoother.
HMike 12 years ago
fullabull69 11 years ago
LoganMackey 11 years ago
i plan on adding wheels this year and extracting like this from now on.
Extracting the honey like this was much much much easier i did it right next to the other hives.
The first time i harvest honey i took the frames out, and extracted the honey in my barn, this was awful the bees swarmed my barn took weeks to get them all out of there. Grabbing hands full of bees and put them into a bucket, pouring them back in there hives.
Using this cart and extracting them at the hives, was SOOO much faster and easier.
First i take off the top super with the lid on, take the lid off and take the inner cover, and put it back on top of the hive stack. Keep the top on top of the super your extracting.
Then pop off the lid pull out a frame, slide off the inner cover shake them back into the hive.
Then after i extract all the honey i put all the frames back in the super and put it back. after the empty the super of the left over honey i usually take off the top supers for winter leaving just the 2 boxes.
HarryStart 12 years ago
zazenergy 12 years ago
