Better Handles for Hanging Your Files
Intro: Better Handles for Hanging Your Files
I have seldom had files with handles. When I did have a handle on a file, it was usually made from a simple piece of broomstick or dowel rod with a hole in one end. The file's tang was jammed into the hole. But, the handle often worked loose in use.
I am also moving into a new workshop space in a different home. I would like to hang many things on pegboard so they are no longer crammed into drawers.
This Instructable will demonstrate my way of adding better handles to my files so the files can also hang on pegboard. Some welding is involved, although I added a step at the end that describes a version without welding.
STEP 1: Tools and Materials
Materials
I placed some aluminum angle into a vise. I used the welder's ground clamp to secure the threaded rod. I held the file by hand and welded the end of its tang to the end of the threaded rod.
- Broomstick or dowel rod
- Threaded rod 1/4 inch in diameter
- 1/4 inch locking nut
- 1/8 inch steel rod
- Thick washer or scrap flat steel
- Vise
- Saw
- Drill and bit
- Wire feed welder
- hacksaw
- grinding wheel
- Aluminum angle
STEP 2: Saw the Handle
Cut a piece of broomstick or dowel rod about 4 inches long. This will be the handle.
STEP 3: Drill a Hole Through the Handle
I marked the center of the handle and drilled a 1/4 inch hole from one end to the other. I did this by hand, but did frequently check the alignment of the drill bit along two axes (This word is meant to be the plural of axis, not a tool for chopping wood.) I sighted from over the bit to avoid deviating to the left or the right. I also sighted from the side to avoid deviating upward or downward.
My drill bit is not long enough to make one hole through four inches of handle. I marked the center of the other end and did my best to drill into the first hole. Fortunately, this worked quite well and my holes met end-to-end.
STEP 4: Slide the Handle Into Place and Begin the Hanger Loop
In the photo the handle has been pushed over the threaded rod and onto the file's tang. (You may have to grind the weld joint where the threaded rod meets the file's tang if the handle does not fit over it.)
I did not have a thick washer, so I drilled a hole in some scrap flat 1/8 inch steel. Then I cut the steel to leave a margin around the hole.
STEP 5: Bend a Loop From Rod
In the photo I am holding the flat steel with a hole in it and a loop made from 1/8 inch rod. I am holding them in about the arrangement that will be used when they are welded together.
STEP 6: Weld the Loop to the Flat Steel
As shown, the assembly is higher in the vise than it was when I welded the loop to the flat steel. This is for a better picture of how it should look when finished. The flat steel can rest on top of the vise to hold it level. The side you are welding first can be raised up a little to lessen the chance the assembly might become welded to the vise. After the two pieces have been tacked together reposition them to finish the welds with good access.
STEP 7: Mount the Hanger on the Threaded Rod
Hold the hanger loop assembly and the locking nut near the end of the wooden handle. Mark the threaded rod and cut it to length. Grind the end of the threaded rod to smooth it.
Place the hanger loop assembly and the nut over the end of the threaded rod. Tighten the nut with the flat side of the hanger loop parallel to the flat side of the file.
Grind away excess from the flat steel and remove any sharp edges. (In the photo you can see the grinding wheel nicked the locking nut in places.)
STEP 8: Finished
Here you see two of my files hanging on the pegboard and ready to use. I still need to make hanging handles from several smaller files still in drawers.
STEP 9: No Welder?
Here is a possibility for those who do not have access to a welder. Grind an indentation or a "V" notch into the side of the file tang. (red arrow) Drill a hole for the file's tang into one end of the dowel handle. Measure the distance from a reference mark on the file to the indentation or "V". Tap the dowel handle onto the file's tang. Measure from the reference mark on the file and drill a hole for a 6-32 machine screw into the side of the dowel handle. (green arrow) Insert the screw to lock the handle on the tang. Cut off the screw and file or grind so it is smooth on the side of the handle. Drill a hole into the end of the handle and screw in an eyelet for hanging the file.
25 Comments
godson1952 8 years ago
Well another thought is ,Drill the wooden dowel and notch the file as you did ,then fill it with clear silicone and then drill a small hole on the opposite end and use a eye screw.Some of people don't have welders.Just another way to do it. ;-)
Phil B 8 years ago
Have you seen the home brew welders made with two transformers from old microwave ovens? I once did an Instructsble on learning to weld, and I linked some home brew welders in it. One interesting approach is a stick welder made from a heavy duty automobile alternator and the engine from a larger lawnmower.
Phil B 8 years ago
allenmorgan 9 years ago
Use old golf balls instead...much quicker...no welding...simply drill a hole for the tang, bang it in...your done. You can even hang it on two pronged peg board holders.
Rune Cutter 11 years ago
Phil B 11 years ago
Steliart - Stelios LA Stavrinides 11 years ago
Wishing you and your family a Merry Christmas and a Happy New Year
Phil B 11 years ago
pfred2 11 years ago
https://www.instructables.com/id/Make-a-Wrench-Organizer/
Even though it is titled Wrench Organizer I think it may work even better for holding files.
Somethingtotallyrandom 11 years ago
Bill WW 11 years ago
You are moving? Are you still just doen the road from me?
Phil B 11 years ago
In opening the photo you can see my pegboard hook jig. The pegboard is 3/16 inch thick. The jig is from a flat piece of 3/16 inch steel. I drilled a hole through the steel 1/4 inch in diameter and placed its center 7/8 inch from one edge. About 3/8 inch from the end of the 3/16 inch dia. rod I make a right angle bend using the jaws of my vise and a hammer to make the bend fairly sharp. I place the rod through the 1/4 inch hole in my jig and clamp the 3/8 inch end of the rod against the jig with the vise jaws. Then I make the other bend in the pegboard hook by hand. It is not really sharp enough, so I slide the rod with both bends and the jig farther into the vise and bear down on the handle. This tightens up the bends some. It is not perfect, but good enough. I turn the bent rod so it points directly to the edge of the jig that is 7/8 inch from the center of the hole and clamp both the rod and the jig in the vise. With one hand I hold the end of a 1/4 inch rod against the 3/16 inch rod using the edge of the jig to position it. Then I tack weld the 1/4 inch rod to the 3/16 inch rod. I reposition the rods so I can finish the weld on the 1/4 inch piece. I cut the 1/4 inch piece so it is around 1/4 inch long and grind away rough edges. Then I cut and bend the 3/16 rod to form the lower part of pegboard hook. I hope that is clear. My hooks fit a little loosely, but they work well and they are sturdy. Those I made recently were done because I did not want to take the time for a run to the hardware store and had some steel rod gathering dust.
Phil B 11 years ago
Even without the wife issue, I have a few tools to master before taking on something else like a welder. My next door neighbor, a woodworker and good friend, passed away this year. I "inherited" his wood lathe, and learning to use it is my next project.
I hope you enjoy it as much as I do :-)
pfred2 11 years ago
RainDog07 11 years ago
Phil B 11 years ago
gomibakou 11 years ago
Perhaps i'm too lazy hehe...
