Bike Hanger Shelf
Intro: Bike Hanger Shelf
This shelf was made from plywood. The design was based on this one... http://media-cache-ec0.pinimg.com/originals/6f/56/dc/6f56dcda1d172d3505e2af1201b6095d.jpg
Steps:
Measure
cut
glue
screw
drill
hang
glue
screw
Steps and materials are shown in picture form.
I plan to fill the screw holes with builders bog and paint. Will update with more photos later.
Steps:
Measure
cut
glue
screw
drill
hang
glue
screw
10 Comments
huskerland3 10 years ago
Arghus 10 years ago
dimtick 10 years ago
it is a little over-structured but i do understand the look your going for.
modern bikes are very light weight.
structurally all that you need are the 2 side piece, a single back board and the top for the shelf.
you don't need the center board, the double back board or the bottom.
sorry if I'm sounding very critical. i really do like this.
would have a lot less screw holes. :)
there are woodworking tricks so that you wouldn't have any expsed screws. simplest is to use metal L brackets or you could put a wood 1x on the inside at each joint and screw into each board from the inside. if you glue the boards, the glue will provide all the strength and the screws are only keeping the joint tight until the glue dries.
I can't tell from the photo, but probably the most important thing is to make sure that the shelf is anchored to wall studs and not just supported by the drywall.
matjos26 10 years ago
rsmithers1 10 years ago
longwinters 10 years ago
I like the idea of having the wheels off the floor, and having a place to put your accessories.
saxmaster765 10 years ago
ojsefg 10 years ago
HollyMann 10 years ago
terielise 10 years ago
