Bookshelf Re-purposed Into Bed!
Intro: Bookshelf Re-purposed Into Bed!
After organizing and tidying up the instructables office a couple weeks ago, we realized we had an extra bookshelf that wasn't needed. I was bummed because I just bought a bookshelf for my room for $30 and the only piece of furniture I needed was a bed... but then I thought there has to be a way I could use it. I took the specs of the shelf and my twin size mattress was exactly the perfect size to fit on the shelf if it was lying down.
Thus, here is my awesome re-purposed bookshelf bed!
STEP 1: Materials
This bed (not including mattress) cost me about $40 including:
Bookshelf - Free
Piece of plywood (1/4" thick, the same width and length of the bookshelf) - $30, you could use any flat board like thing that does not bend easily
Screws (8) - approx. $1
Contact Paper - $10. You can keep it simple with clear contact paper or get more exciting with animal prints!
Screwdriver - already had
Drill - already had
Although you may not be able to find a bookshelf for free, check out yard sales and craigslist. You will be surprised how cheap you can get them for. They are often much cheaper than buying a used bed frame. Also, make sure the edges of the bookshelf are thick like this. If they are thin the bed will be flimsy and may not support your weight and it will be hard to attach the plywood.
STEP 2: Attach Plywood
Mark on the plywood where you will be drilling. Put two screws in each corner of the plywood and shelf. I measured it out so the screws would be exactly the same distance from the corner and in the middle of the shelf frame (i.e. the thickness of the frame of the shelf and the shelves is 2", so the screw is 1" from the edge )
Drill a starter hole for the screw so the wood doesn't split and the screw goes in easily. Then drill the screws in.
Sorry about my final picture. I took it at a weird angle and thought I would be able to just rotate it 90 degrees, but it didn't look good (or give me a headache) at any angle but this.
STEP 3: Attach Contact Paper
Measure the contact paper so it covers the entire bed and stick it on the wood. This is pretty self explanatory. I used two types of contact paper and made stripes!
You can see the paper hangs over the edge. Cut it so it's all the same length. (You can see its the same length in the next step)
29 Comments
M.C. Langer 11 years ago
Two questions: how much did you pay for the mattress? Where can I find an economic mattress? In february 27th I will move to San Francisco for three months, and If I can't find a room with bed, I will need to make my own bed!
lharmon2 11 years ago
pddonovan2011 12 years ago
What you have here is a prime example of exactly that motto, you have done yourself proud!
Friendly critique! Contact paper = good, sand and paint = better. 3/8 foam covered with dark brown (Colored to closely match the color of the shelves!) vinyl upholstery = best! (NO SPLINTERS WHEN MAKING THE BED!)
I'm going to turn-on people to your instructable, because it is PRIMO!
jtharkness 13 years ago
verbatin01 13 years ago
This isn't exactly retaining bookshelf capability, but you could try repurposing with additional functionality, like so:
As long as the flat bed support (plywood or pegboard, as another suggested) is screwed into the bookshelf as shown in the vid, you have enough support to be able to cut off one side and use the frame as segmented storage. To make it even more convenient, place cheap towels with a 2x4 board stapled on the end of the towel. Place stuff on the towel, then slide the board down the seg.ment with a yardstick. Anytime you want to access the stuff, just pull the towel out. To make it look nice, buy a couple of hinges from your local hardware store and latch it using velcro across the vertical members (the "shelves"). Check out the 3M industrial velcro - it can support a LOT of weight.
bobster580 13 years ago
Sherlock69 13 years ago
marcintosh 13 years ago
Again, in case you missed it- Stunning
Thanks
renni 13 years ago
raymccullie 13 years ago
cindym 13 years ago
achong0 13 years ago
porcupinemamma 13 years ago
alaricsp 13 years ago
rexdino5 13 years ago
l8nite 13 years ago
suckrpnch 13 years ago
Carleyy 13 years ago
paronomasiac 13 years ago
sillyzombie666 13 years ago
