Boost Volume With Paper Cups
Intro: Boost Volume With Paper Cups
When you want to share your music with friends headphones just aren't loud enough. Fix that with cups to boost volume!
STEP 1: Materials
Below is a list of materials.
STEP 2: Trace
First you will need the cups, pen, and a speaker. Take the speaker and place it on the cup as desired and trace around it.
STEP 3: Poke Guide Holes
Now you will need to poke some guide holes on the edge of your circle with your tack. (this step will make it a lot easier to cut)
STEP 4: Cut
Take your knife and cut out the circle and follow the dots.(BE CAREFUL)
STEP 5: Check Your Work
Make sure that the hole is not two big and not two small.
STEP 6: Cut Slot (optional)
You can cut a slot for the wire if needed.
STEP 7: Glue
Glue in the speaker to the cup.
STEP 8: Repeat Steps 1-7
Make a second one.
STEP 9: Done
You are done music should be much louder to share with friends
2 Comments
Lorddrake 12 years ago
benbar12 12 years ago
