Boot Survival Kit
Intro: Boot Survival Kit
Hello again! I'm back with another survival kit for y'all!
If you've ever feared that you were not prepared for a survival situation [such as getting lost in the woods] or perhaps you want extra redundancy in you survival system or maybe you simply want to carry more items without taking up precious pocket space then this instructable is for you!!! Pull yourself outta whatever situation you find yourself in by your bootstraps! Literally!
See this kit and more on my new YouTube channel!!!
http://www.YouTube.com/user/BudgetBugout
Things you will need:
Paracord [at least 15 feet]
Lighter
Pliers/Multitool
Scissors/Knife
Gorilla Tape [optional]
Nathan Shoe Pocket
Ka-Bar Last Ditch Knife
Lighter
Pliers/Multitool
Scissors/Knife
Nathan Shoe Pocket
STEP 1: Step 1
1st step, Unlace boots and layout shoe string and paracord. Cut two lenghts of paracord equal to the length of shoe string. [6.5 feet of paracord each]
Survival tip: Why replace bootlaces with paracord? Good question, there are multiple uses for paracord due mainly to it's strength [it can hold 550 lbs of weight] and it's inner strands [5-7 strands].
Basically, if you are in a survival situation you want cordage, but you are going to need your shoes too. Simply gut the paracord [pull out the inner strands] and relace your shoes and now you have another survival tool!
See 80 Uses for Paracord for more details. :)
STEP 2: Steps 2 & 3
Burn ends of paracord with lighter and immediately press tips into points [Caution, use pliers to mold ends of paracord! Melted paracord is very sticky and burns on contact!]. Remember, the finer the point of the paracord the easier it is to pass through shoelace eyelits so repeat these steps as needed.
STEP 3: Step 4
4th, Lace up boots. Use pliers if needed to pull paracord through hole but be gentle not to crack the tips of the paracord, you dont want to increase the diameter of the tip.
STEP 4: Step 6
Attach velcro pocket pouch to shoe laces. I placed Gorilla Tape on the reflective part of the pouch.
STEP 5: Step 6
Lace up other shoe with the boot knife, some eyelits on boot knives may be small so be patient getting the paracord through. This was the most tedious part of this kit for me.
STEP 6: Final Step
Hurray! Now the fun part of choosing what goes inside of the pocket begins. These are some items that could fit into the pocket [the thing with the squirrel is a box of matches], I would recommend a firestarter at a minimum.
STEP 7: Happy Trails!
Now you're free to roam wherever your boots can take you!
28 Comments
LegoSurvivor 6 years ago
The cat is gonna shrink yo boots and survive with them.
DanK39 6 years ago
love it. I use shrink tubing on the tips of the paracord to make my own aglets. It keeps the cord together without melting the ends and once shrunk tightens the tips to help them go through the eyes better.
Amonty24yiger 7 years ago
Awesome tutorial! Just got these
http://www.maelstromtactical.com/footwear/boots/maelstrom-tac-force-8-black-waterproof-tactical-boot-with-zipper.html and it worked like a charm! Thanks for the help.
CameronA15 8 years ago
I use p-cord laces on all my boots being that i am a boy-scout you never know when you may need it. I find that if you are using steel toed boots out at least 10 ft on each foot (so you can wrap the p-cord around the ankle a couple of times) I've found that using the outer sheath of the p-cord works for tennis shoes better then all of it (keep in mind this reduces the overall load bearing strength to 200 lbs? i may be wrong) At any rate I my self do not like to use shoelaces except in my bowling shoes because i do not where those that often.
Darkman 8 years ago
Kandiklown 8 years ago
rizingf3nix 10 years ago
Keep rockin' it. Great idea!
StanJ2 8 years ago
Heat shrink tubing ... kicking myself now .... great idea ... simple solution.
darman12 10 years ago
BudgetBugout 10 years ago
GM1558 8 years ago
Great idea, maybe for some smaller people we could leave the cord a little longer and wrap around the boot. Just in case we need extra length for an emergency.
synchronous0987 8 years ago
I'm pretty sure your supposed to keep those on the ankles, to keep safe and dry. Everything in that pocket woul be destroyed in ten miles with me.
rvincent2 9 years ago
and a cat to help :3
unclelar 9 years ago
I agree with micah50,been using paracord on all of my boots,(hunting,fishing and hiking). I have always double knotted and have never had them come loose.Nice job on the ible,may try this idea on my hunting boots seeing as how in my area deer season is opening very soon.Nice job
350smallblock 9 years ago
apk2000 10 years ago
Halphinian 10 years ago
the knotty biker 10 years ago
ljsdraper 10 years ago
micah50 10 years ago
