Brass Knitting Needles
Intro: Brass Knitting Needles
Quick knitting needles made from 1/8" solid brass rod.
STEP 1: Materials and Tools
I purchased a 3' long 1/8" diameter brass rod from a local hardware store.
The project requires a hacksaw and sandpaper. However, a ruler, clamp, grinding wheel, leather gloves and eye protection will make the work faster and more comfortable.
STEP 2: Cut the Rod
I marked every six inches along the rod. I clamped each section and sawed off each piece with the hacksaw. I then had six 6" sections.
STEP 3: Shaping the Ends of the Needles
I turned on the grinding wheel and shaped both ends of each rod. I held my hand steady and rotated the rod at a nice blunt angle. I used sandpaper to smooth the surface, but all of the shaping could be done with sandpaper. I used a match striking motion to get a slightly rounded tip.
STEP 4: Get to Knitting
Try out the needles. I like this set for making small creatures and tiny tubes. This probably would be a fine set for socks.
8 Comments
nords 8 years ago
You can make the knitting needles out of aluminum. It will be a bit softer than the brass but much lighter. Since it is an element and not an alloy, there shouldn't be any other component to it.
The Green Gentleman 11 years ago
That said, these look very nicely made!
jesse.hensel 11 years ago
There is no reason this project needs to contain any hazardous materials. Knitting needles can be made from a wide variety of materials. I recently posted an Instructable that shows how the discarded branches from pruned trees (free, local, sustainable, non-toxic) could be used to make knitting needles: https://www.instructables.com/id/Street-Knitting-Needles/.
Thanks,
Jesse
http://www.sciencedaily.com/releases/2010/11/101111141849.htm
I got started on the anti-brass kick a few years ago when I was doing electrolysis of water and NaCl using brass electrodes. An orange-red precipitate formed during the process that turned out to be a form of lead (II) oxide, formed when the lead leaching from the brass reacted with the (somewhat caustic) solution.
Most brass has some lead in it currently (at least in the U.S.) - from my reading, the lead content is not limited to plumbers brass. There is some truly lead-free stuff out there, but it's more expensive.
Penolopy Bulnick 11 years ago
