Buffalo Leather Sheath for a Carving Knife
Intro: Buffalo Leather Sheath for a Carving Knife
This time I make a buffalo leather sheath for a carving knife that I made. The knife is made of padauk wood and buffalo horn, so I decided to go with the buffalo leather for the sheath. Buffalo leather is very soft but a lot stronger than cow leather. I used only a few very simple tools for this project. You can easily DIY too...
STEP 1: Blade Wooden Cap
The first step was to create a wooden cap to protect the knife blade. The sheath is made of soft leather and therefore the blade was not sufficiently protected by the leather itself. I had already created this piece time before the sheath, so I have no photos of the realization. It is simply made of three layers of thin wood glued together.
STEP 2: Cutting the Back Leather
I chose a piece of brown leather, not too thick, to make the back of the sheath so that it stays flat. Using a paper template that I had previously drawn, I accurately cut this piece of leather. Using again the shape I then made the cuts for the belt, without removing the material inside them.
STEP 3: Cutting the Front Buffalo Leather
The front of the sheath is made of robust buffalo leather. I cut this leather very roughly because it will be cut precisely when the two parts are glued together, following the contour of the back.
STEP 4: Insulating the Knife Handle
To protect the knife handle from the glue I used in later work, I've completely covered it with transparent film. In this way, I avoided the wood sticking or ruining.
STEP 5: Cutting and Glueing the Leather Edge Protection
To protect the leather in the area where the knife is inserted, I added a small thin skin thimble. This piece also has an aesthetic function as it hides the edge that would otherwise remain visible. The piece was first cut and then glued up.
STEP 6: Sewing the Leather Edge Protection
Once the glue dried I sewed this piece by using a thick and colored thread. I first pierced the skin to make it easier to sew. I then used an old stitching awl to help me doing the job.
STEP 7: Glueing Pieces
It was then time to glue the pieces together. Using some strong glue I first glued the wooden cap and inserted the knife. I then laid the glue over the whole piece and adhered to the top leather. I used clamps to make the leather adhere firmly to the knife. I then waited for it to dry.
STEP 8: Cutting the Excess
Once the glue was dry I cut off the buffalo leather excess with a sharp knife.
STEP 9: Sewing the Sheath
It was then time to sew the sheath along its edges. This is certainly the longest part of the whole process. It is also the one that requires more precision. Seams also have an aesthetic function and they must be done with care. I first pierced the leather with the appropriate tool. Then, as I did before, I stitched all over the perimeter of the sheath using the stitching awl.
STEP 10: Refining
The last step was to refine the sheath so that it looks finished. In particular, I first cut the belt passers carefully. I then finished all the edges of the leather passing over some paraffin and then burning them with a hot solder.
STEP 11: Final Shots
The sheath is now complete. Here are some shots of the final product.
Thanks for checking this Instructable. There is also a video of the realization of this wall clock on my YouTube Channel . You can watch it to have a better idea of all the steps, especially the hand sewing part.
14 Comments
cycle ninja 6 years ago
Excellent choice on buffalo leather, as it is very strong and flexible as well as moisture resistant. I was looking for another type of leather for my next holster, and after reading your instructable, my mind's made up. Thank you for the idea and tips, will post a pic as soon as its done.
Guido Vrola Design 6 years ago
Great! Inspiring others is my greatest motivation!
cptoh 6 years ago
holder for sale ?
Not for the moment, sorry.
jpmarth 6 years ago
Impressive results! Quality work.
Thank you very much!
4DIYers 6 years ago
Stunning work!
Many thanks!
cptoh 6 years ago
cptoh 6 years ago
product . Do you also consider to accept order handphone side holder
for sale.. thank you .
MillennialDIYer 6 years ago
Would a SpeedyStitcher be a good tool for a project like this, or is something smaller more preferable?
Yes, a Speedy Stitcher should surely work well for a project like this!
seamster 6 years ago
Wow! This is beautiful work. Very nicely done.
