Bug Out Bag First Aid Kit
Intro: Bug Out Bag First Aid Kit
In this instructable I will be showing you how to assemble a first aid kit for your bug out bag. For those of you who are new to the concept of a bug out bag please check out this link to the Wikipedia page. http://en.wikipedia.org/wiki/Bug-out_bag
When you are in a survival situation you are almost guaranteed to have some kind of first aid need that will arise. Not having a well assembled first aid kit in an already chaotic situation can make everything much worse.
we will start with the pack itself:
The pack is made by Voodoo tactical (http://www.voodootactical.net/p-1075-voodoo-tactical-molle-utility-pouch-new-resue-red.aspx)
It is a MOLLE compatible first aid pouch with heavy duty zipper. This bag cost around $15 dollars, I bought mine at a local store but they can be purchased from the link.
You want your first aid kit to be the last thing loaded into your Bug Out Bag as it needs to be easily accessible. Your first aid kit should be easy to find in your bag based off of site and feel.
STEP 1: CPR Pocket Resuscitator
This is a crucial item to have in your first aid kit. a pocket resuscitator for doing CPR allows you to perform CPR on an individual and potentially save their life.
I purchased this model on eBay for around $10. The one feature that you want to make sure that your CPR mask has is a one way valve. Often times a person receiving CPR will vomit, this valve will keep that vomit out of your mouth. also look for a mask that comes in a nice hard case and includes gloves.
STEP 2: Wound Suturing/Closure
There is a good chance that during your survival period you or a loved one will become lacerated in some fashion that is beyond the capabilities of a bandage, for that reason I like to keep a couple of suturing options in my first aid kit.
option #1:
sterile packed suture with attached needle. these can be found on eBay for quite cheap around $2 a piece, it is also a good idea to have a couple of sterile packed scalpels to go along with this part of the kit.
option #2:
Sterile packed skin stapler and separately packed staple remover. this can be an invaluable tool if someone is injured as it requires very little technical know how. these can be picked up on eBay for around $15 for the set typically.
option #1:
option #2:
STEP 3: Bandages and Gauze
This is pretty straight forward you should have a multitude of bandaging options and mine personally includes:
1 ACE elastic bandage with metal clips
1 roll of gauze
2 non stick gauze pads 3x4 inches
1 roll of medical tape
2 large bandages
5 regular bandage strips
4 butterfly closures
1 roll of gauze
2 large bandages
STEP 4: Miscellaneous Items
Some of the other items that your first aid kit should contain are as follows:
Hand sanitizing wipes
Antibiotic ointment
Alcohol wipes
tweezers
cotton swabs
Latex gloves
cotton balls
thermometer
Scissors
Ibuprofen pills in a small watertight bottle
antihistamine pills in a small watertight bottle
and bismuth pills also in a small watertight bottle.
Antibiotic ointment
Alcohol wipes
tweezers
cotton swabs
Latex gloves
cotton balls
thermometer
Scissors
STEP 5: In Conclusion
Remember that your first aid kit should be tailored to your personal needs. You should include backups up any prescription medicines that you take and be sure to pack extra contact lens solutions if you need to.
Also keep in mind that the point of a bug out bag is to keep you safe for 72 hours during a disaster, it can be easy to overpack and get carried away. You should just try to be thorough but not overexcessive, but of course this is at your own discrection of what you feel comfortable carrying.
Thanks for reading. and let me know if you have any questions in the comment section.
23 Comments
MarkC94 8 years ago
conradcst 11 years ago
travcoman45 9 years ago
Remember, tampons and maxi pads are designed to absorb blood. I would recommend using a sterile gauze on the wound and then add the maxi pad to absorb any blood that would leak through.
zman1204 9 years ago
hankadopolis 11 years ago
norma.wood3 9 years ago
Not true. The victims will not always vomit but usually they do. I was a first aid/CPR instructor and I never saw anything that supports your claim.
minerug 11 years ago
AmyCat59 11 years ago
grt57 11 years ago
Then you could trade the smokes for more zombie bustin' .226 rounds. Or take up smoking after 20 years, seeing as the end is near.
queerpuppy 11 years ago
I'd also add first aid training. You need to be able to use those things properly, and be so well versed in techniques you can do them whilst panicking / in pain / shocked etc.
QuestionConvenience 11 years ago
Also space blankets can be used to treat hypothermia, which is probably the most likely problem out-of-doors.
Also, coming from an EMS perspective, you're a little heavy ended here - a lot of redundancy but not a lot of variety. I would forget the bandaids and skin-stapler and opt for bigger, more universal supplies - think stuff to clean wounds out with, stuff to close wounds up with, stuff to help people move to where you can get definitive care. Along those lines 2x2 inch guaze pads, 4x4 gauze pads, small bottles of H2O2 (or saline if have it), large fabric splints, maybe a SAM splint, maybe even a quick clot. Try not to include stuff that will tempt you to undergo open-heart surgery, just keep it realistic - think through what might happen (lacerations, falls, broken bones/sprained joints, hypothermia, etc) and prepare for as many as possible.
And above all else, learn how to recognize and treat stuff before you need it. And brush up regularly.
Stay safe! Good work, keep refining!
pepperetters 11 years ago
Twistedsense is good sense! (post below)
As for the other suggestions... I agree. The kit as described has sufficient (maybe overkill) supplies for dressing wounds. The wound closure pieces are redundant. The suture is essentially useless without proper instruments. If you are going to carry a stapler, don't bother with the suture. It is easier to use and requires less gear. The only place not to use it is the face, though if you are in a true survival situation i guess it would be ok. Steri strips or butterfly bandages will work as well as anything unless your wound is under tension. I would suggest adding mastasol or a similar product to help the steri strips stick.
A space blanket or heavy plastic sheet (or large heavy duty trash bag) can do wonders for heat loss (very common with traumatic injuries!). A SAM splint is great for splinting fractures. Knowledge and training will go farther than any item in the kit.
Last thought... think of things that will kill you that you can actually use with minimal training... a penetrating injury to the chest can create a sucking chest wound... add a chest seal or make sure you have the materials in your kit to make one. A tourniquet will be more beneficial in life threatening limb bleeding than any of the dressings you include (though they are important too). If you are serious about your kit, consider asking your medical provider for prescriptions for antibiotics and any other medication you think you might need.
3.1415 11 years ago
The new ratios are 30 compressions to 2 breaths.
mac9000 11 years ago
mjh2901 11 years ago
Y-Geo 11 years ago
as stated else where this is very "serious" kit which realy needs good sound knowledge to use properly. Being ex-military and working in small groups or alone I learned to pack 2-3 "feminine sanitary towels" which are very useful as wound dressings & pressure pads for heavy bleeds (knife, gunshot or shrappnel ) also easy to obtain just about any where in the world without raising a set of questions.
twistedsense 11 years ago
As I don't know what your medical training experience is please take what I say with a grain of salt.
If your using the sutures and stapler as a temporary fix until you get to a ER with a few hours than okay but from my experience sutures should not be used except by a trained professional, unless you are trying it on yourself and don't mind the potential for complications.
If you injure yourself in a bugout situation steri-strips, butterfly closures or even gauze pads secured with duct tape, ace wrap or coflex are a better solution. By closing a wound with sutures you take a big chance of locking in bacteria and causing an infection. Plus you could do more damage than good to the surrounding skin if you are not fully trained in suturing.
If it is a large wound and you have the bleeding under control you can pack it with sterile gauze and wrap it with coflex or ace wrap. Then change out the bandage at least once daily until you get to your bugout location where you can get better care. Bigger wounds heal from the inside out so as time goes by the wound will get shallower and shallower.
tldr; for most people steri-strips or butterfly closures would be a much better idea than sutures if you are not a trained medical professional. Youtube is not always a good idea
Rusty101 11 years ago
