Buidling a Steampunk Mini Computer for the Ladies Desk
Intro: Buidling a Steampunk Mini Computer for the Ladies Desk
Most computers are ugly, made of plastics and have ultrabright blue LED´s to "brushup" its design. ;-)
Tired of those "Desktop Devices" I builded a small, nice looking computer. Even for the desk of a lady.
The plan was to have a computer that is able to browse the web, read mails, write letters and do some calculations with a spreadsheet program. Wireless was a "must" for this computer.
STEP 1: The Mainboard
I found a 12cm x 12cm nano ITX Mainboard on the internet. The board has a lot of features:
12V single Power
500 MHz Geode CPU
MINI PCI - Slot
Capable to drive up to 1 GByte of RAM
Sound pn Board
Ethernet 10 / 100 MHz on Board
VGA on Board
2 USB 2.0 on Board + 2 USB 2.0 on an external cable
CF Slot for the secondary IDE channel
44pin IDE Port that connects direct to a Ntebook HDD
So everything you need to build a whole computer.
Additional parts:
1 GByte Ram
1 WIFI Card
1 Pigtail WIFI connector
1 WIFI antenna
1 Power switch
1 Reset switch
12 V Power supply.
12V single Power
500 MHz Geode CPU
MINI PCI - Slot
Sound pn Board
VGA on Board
Additional parts:
1 GByte Ram
1 WIFI Card
1 WIFI antenna
1 Power switch
1 Reset switch
12 V Power supply.
STEP 2: The Case
I decided to build a case out of wood and slotted aluminium metal plate.
Parts:
2 pieces of wood 12,5x12,5 cm 6mm thick
2 pieses of wood 13,3x13,5 cm 6mm thick
4 pieces of aluminium metal plate (see pictures) 12,5cm x 6 cm
4 brass profiles (see photo)
1 piece of wood 20cmx10cm 21mm thick for the stand
some brass screws and washers
I drilled 4 holes in the smaller piece of wood for the srcews to mount the mainboard. The harddisk is located underneed the board.
I glued the second pair of wood pieces together to build the top of the case.
In both I drilled a big hole for the airflow and 4 holes for the baring, we will see later.
I used wax stain in mahogany colour for all wooden parts.
Parts:
STEP 3: Mounting
Harddisk and Mainboard.
The backplane with USB Ports and reset switch.
STEP 4: The Bearings
The bearings are made of two thin slices of wood with brass applications.
I covered the bigger peace by a red cord with brass endings.
The brass nut covers the power switch.
On the opposite side of the case there is the WIFI antenna and the angle bracket for mounting the computer on the stand.
The stands have been bought in a clockworkers shop called SELVA.
STEP 5: Operation
The computer runs DEBIAN with OpenOffice. It is fast and everything works smooth.
Thank you for reading,
JnEn AKA Horatius Steam
18 Comments
joy2b 11 years ago
I don't see a reason to hide the antenna. It looks almost like a hand crank arm (that could be assumed to be powering the computer). You could glue on a light piece of black plastic or wood on a right angle if you wanted to get that look. If the black plastic look isn't appealing but you want to avoid metal, painting on wood grain or enamel is appropriate.
Here's some crank arms for illustration: http://www.allmetricsmallparts.com/products/handwheels.htm
pudtiny 11 years ago
Horatius.Steam 11 years ago
it wouldn't really impact on the design then
Thank you. this is a good idea :-)
stringstretcher 11 years ago
I tried to use brass, copper and bronze paint.
Bad idea ;-) because there the metal partials in the paint miss tuned the antenna completely and the reflections back into the electronics destroyed the transmitter.
Beside this the link quality is very bad with a covered antenna.
Next thing I tried to build an antenna by my own.
I found a lot of fractal antennas but I needed a 360 degree antenna.
If someone have an instrutable for such an antenna, please let me know.
With kind regards,
Horatius Steam
imbigman 12 years ago
Horatius.Steam 12 years ago
With kind regards,
Horatius Steam
SDgeek 12 years ago
zack247 12 years ago
The RAM ist on the back of the board. The mini PCI slot the same- This is one reason why the board is so small. They but the components on both sides of the board.
if it wasnt for the 500mhz processor i would definitely look into one of those, but even 500mhz would be fine if you arent looking to play games on it.
siafulinux 12 years ago
brunoip 12 years ago
The board is drawing 2,1 A from the power supply on full operation (video playback)
