Building a Whiskey Still
Intro: Building a Whiskey Still
I will be explaining how to "theoretically" make a distiller (Whiskey Still). (this Instructable is for learning purposes only as I am not sure of your local laws. i take no resposibility for your actions!)
The still shown below was given to my grandfather as a gift, but it is a fully working still which would theoretical create distilled water, alcohol, etc (we never really tested it). It may not be homemade, but it is perfect for explaining the basic process.
Please remember to vote if you like my Instructable.
STEP 1: The Process
First, i will explain the process of getting alcohol.
To start you need a "Fermented Mash"- "Braga" (recepies will be at the end). The braga is what originally contains the alcohol.
Once you have the braga, you will place it into into the container which is heated. The braga will boil, causeing the alcohol (which has a lower boiling point than water) to evaporate, go up the tube, and into the "Zmeevik" (curly tube in the refrigerator, aka the condensator). In the zmeevik, the alcohol condensates (do to the lower temperature caused by cold water in the refrigerator) and drips into the cup (or bucket if your makeing a lot).
Make sure the thermomiter never goes above 90 degrees(centigrade) (at 100 degrees (centigrade) water starts to boil; if this happens, it means there is no more alcohol in the braga).
You can now through the alcohol-less braga away.
Congradulastions! You have made your first "Samogon" (which means self distilled or moonshine).
STEP 2: Making Your Own Still
You will need:
1)a kettle (the kind you put on the stove to heat)
2)a copper tube (a few yards)
3)a bucket
4)a bottle
5)a thermometer
6)a drill
7)a drill bit with the same diameter as the thermometer
First, you need drill a hole in the lid of the kettle. Into the hole, insert the thermometer and glue in place with a thermally resistant glue, making sure that the glue forms an air-tight seal around the hole.
Now you have to make your zmeevik. Take the copper tube, find a larger round object, like a fire extinguisher, and wind the tube around the round object. Remember to put sand in the tube so that it doesn't bend flat. Leave a length of tube at the beginning and end of the tube (end A & end B). It should be a spiral.
Drill a hole with the same diameter as the tube near the bottom of bucket.
3)a bucket
4)a bottle
5)a thermometer
6)a drill
STEP 3: Braga!!!
This is probably the most important part of your samogon. Without it you cannot make your moonshine.
This part is relatively easy. The recipes!:
1*)600 gramms sugar, 20 gramms yeast, 3 litters water: mix everything together & set in a warm place for a week.
2)600 g. syrup, 20 g. yeast, 3 litters water: see (1)
3)a can of tomato paste, bottle of beer, 1 kilogramm of sugar, 3 litters of water: mix ingreidients, let sit in a warm place for 4-5 days.
To make whiskey you need a braga made from mashed up barley (the process is much the same).
- I used this one
STEP 4: Distilling
Put the prepared kettle onto the stove (or hot plate). insert end A of the zmeevik into the kettle spout and seal it. (to seal holes, use a "dough" of water and flour, (not too wet) and smear it over the holes, then wait for it to dry.) Pour your braga into the kettle and seal the lid onto the kettle. Put end B of the zmeevik through the hole in the bucket, seal the hole, and fill the bucket with cold water. The bucket should be on a stool or table or something so that the zmeevik isn't strained. Put the bottle you prepared earlier under the opening of end B, to collect the spirit that will flow from your still.
Make sure everything is air-tight.
Now you can light the stove (turn on the hot plate), so that the braga starts boiling.
Make sure that the thermometer never goes up to 100 degrees centigrade. At 100 degrees centigrade water startes boiling and instead of booze you get water vapors.
The first 100 ml of ever liter and last 300 ml of ever liter of your samogon should be thrown away (poured down the drain) because the contain harmful chemicals.
STEP 5: Filtration
When your pure-ish alcohol from your braga has been distilled the first time, you have to filter it.
Take natural wood charcoal (without lighter fluid), grind it into a powder, and place it into a bottle with you samogon. Close the lid and start shaking the bottle. when afterwards take a clothe or bangage and filter the concotion ( this is just to keep your still clean) and pour it back into the kettle. Repeat the distilation process.
For really pure alcohol you ned to do the distilation and filtration process 3-4 times.
STEP 6: Testing
To test the purity of your alcohol you need Potassium Permanganate (KMnO4).
Take a little of your alcohol, put it in a seperat glass, pour in a tiny bit of KMnO4. If the Alcohol turns pink/purple it is "unclean" and should be distilled & filterd again. if the alcohol becomes slightly pink or stays clear, it is safe to drink.
STEP 7: The End
Congratulations! You have learned how to make a still and how to use it.
Remember, you have to dilute the alcohol so that only 40% of your drink is alcohol (you about 100% alcohol from your still). Mendeleev, (the guy who made the periodic table of elements) researched vodka, and discovered that 40% alcohol is the best proportion.
P.S.: to make whiskey you need to use barley braga and keep the resulting alcohol (diluted to 40% alcohol) in an oak barrel for at least 3 years. (I'm not sure, but I think the filtration method is the same).
P.S.S.: Remember, THIS IS REAL ALCOHOL! the laws of your country, state, etc. apply.
Alcohol is not recommended for children younger than 18, pregnant women. Do not drink alcohol and operate heavy machinery. Read a vodka label for the full message.
90 Comments
Travis Moran 6 years ago
kakashibatosi 9 years ago
The alcohol does not come out at 100%, it comes out closer to 70%. In order to get 100% the distillate has to be distilled again a number of times to leave behind the water that comes with it.
marcus.killian.10 8 years ago
Leathaldose 9 years ago
why is your still so dusty? mine would shine from over use like a mirror.
rodpaget 9 years ago
basically the stuff that we get in cars nowadays has good ole corn whiskey in it. Before it leaves the refinery by law 15% gasoline goes in to make ya go blind.....I work at a corn ethanole refinery Canada
clayandnatashia.phillips 9 years ago
Lokisgodhi 10 years ago
To legally distill you need a license from the BATF.
http://www.ttb.gov/spirits/
Eirinn 13 years ago
I'm guessing the permanganate triggers on methanol?
coffee steam 12 years ago
It evaporates sooner (lower temp) than the drinking alcohol, so you throw away the first stuff that comes out of your still, since any wood alcohol and acetone (tastes nasty too) comes out first if you heat it up nice and slow.
You can get a digital thermometer for about $15 from most large hardware stores, so you can tell when to start collecting the drinkable stuff.
www.homedistiller.org has a LOT of info on this.
jkeillor 11 years ago
Source: http://whiskyscience.blogspot.co.uk/2011/02/oaky-flavours.html
So it seems that yes, if you're keeping control of the temperature, you shouldn't need to worry too much about tossing out too much wood alcohol goodness.
Lee Wilkerson 11 years ago
Ethanol (C2H5OH) is made by anaerobic respiration of sugar and an enzyme found in yeast. It is less toxic, but can still damage internal organs most notably the liver (cirrhosis) if consumed in large quantities.
The Potassium Permanganate triggers on the pollutants in the distilled liquid.
gorillalblack 11 years ago
Dr Quest 14 years ago
http://www.coolest-gadgets.com/20090309/the-missisipi-distiller/
lx2036 12 years ago
deth2all 15 years ago
DeLorean4905 15 years ago
neffk 12 years ago
Yeah. And to get even close to 95%, you need a well-designed refluxing still, not just a hillbilly pot still.
densad 15 years ago
Gilo 15 years ago
