Built-in Wireless Light Box With Secret Storage.
Intro: Built-in Wireless Light Box With Secret Storage.
One of my resolutions this year was to do more artwork. Toward this end, I ordered a large coffee table with lots of storage to put art supplies in so I could draw while relaxing in front of the TV at night. I wanted a light box as part of this "art station," and at first was going to cut a part of the table top off and replace it with plexiglass, but came up with this easier solution instead: a built-in light box using one of the drawers.
This light box is wireless, using battery-powered LEDs purchased at the Dollar Store (making this a very affordable solution as well). In playing with the lighting, I discovered that placing a white foam board at an angle under the plexiglass gave me the most light "bounce," as it reflected the LEDs upwards. This angled board in turn created a "secret compartment" for storing paper, pens, etc.
WHAT YOU WILL NEED
Brilliant white foam core or cardboard
Translucent white Plexiglas to fit top of drawer
Several touch-operated LED lights from the Dollar Store
AAA batteries (3 per LED light)
1" wood screws (2 per LED light)
Strong magnet
Small rare earth magnet
Ferrous metal piece (about 1/2" x 1")
Sharp blade
Ruler
Glue
Epoxy
Screwdriver
Sticky putty
WHAT YOU WILL NEED
Strong magnet
Sharp blade
Ruler
Glue
Epoxy
Screwdriver
Sticky putty
STEP 1: Bank of Lights
For my light box, I screwed in a bank of seven LED press-to-operate lights to the back side of the drawer--each with three LEDs. I could have mounted them with the sticky back of the LED light, but I wanted to minimize bulk (and trim them to fit as high up as possible), so I stripped off all the extras on each light, flipped the light around to the battery side and screwed them into the drawer permanently.
All I have to do when the batteries wear out is pull them out and replace them.
The video in the intro shows how I did the above.
STEP 2: Light Box / Storage Structure
The structure of the light box is composed of:
1. Three foam core pieces for the two sides and the front of the drawer measuring 1/4" from the top.
2. One foam core piece for the front of the drawer measuring 1 1/4" from the top.
3. One foam core piece that sits at the rear bottom of the drawer and lays at an angle on top of the shorter foam core piece at the front of the drawer (see video at 4:15).
4. One piece of plexiglas that fits snugly inside the drawer (it will rest on top of the foam core pieces and the LED lights).
Glue the first three pieces directly to the drawer, and the shorter front piece to the first front foam core piece, bottom side touching.
STEP 3: Magnetic Latches
This light box has two magnetic latches. The first latch is made by hollowing out a piece of the bottom side of the slanted foam board and inserting a small rare earth magnet. Put glue in the hole, drop the magnet in, and glue a small piece of paper on top. This magnet will be completely invisible.
The second latch is made by gluing a piece of ferrous material (steel, iron) to the top of the plexiglas. I used a random piece of metal that was screwed onto the bottom of a full-sized door. Glue it onto the plexiglas with epoxy.
To open these latches, make a pull by gluing another strong magnet to the end of a wine cork (I had to use epoxy, as school glue just pulled away).
STEP 4: Hidden Light Box
Tuck your finished light box back into the coffee table. Use as needed.
28 Comments
Yonatan24 8 years ago
Cool! LED strips could work well here...
MarcioWilges 9 years ago
Storage is always welcomed around the house and if it is possible, we would gladly include at least some additional storage area at every corner of the house. Boxes make good storage solutions because of their abundance of space for us to store almost anything and everything. What we need to do is to simply make those boxes look nice and merge into the background of our furniture pieces so as to conceal the real motive of it. Then, our guests would not know what the mess that they actually behold inside.
UdyRegan 9 years ago
That's a beautifully simple DIY tutorial, thanks so much for sharing this! I think my wife might enjoy this if I installed it in one of our coffee table storage drawers, she tends to pick the weirdest times to want to doodle - like when we're watching TV or just having a coffee. And it's almost always dark out so the LED lights would really help a lot!
flyingpuppy 9 years ago
Super Pixle Man 9 years ago
How difficult was it to make this? Can one complete this on a VERY low budget?
Kadash 10 years ago
It looks awesome ! I have an old desk which is ready for an update, but I'd like to know how thick the glass have to be ? Before I start breaking anything ^^
And thanks flyingpuppy for the instructable !
flyingpuppy 10 years ago
Kadash 10 years ago
Thanks ! I'll gather everything I need this afternoon :)
steelyray 10 years ago
White mylar (drafting acetate) also works well for a diffuser if you have a sheet of clear glass or plexiglass.
kariswg1 10 years ago
....great idea...where did you get the opaque Plexiglas? I can only find the clear type locally.
Erfunden 10 years ago
I've made a large light box using clear plexi. You just have to spend some time sanding the heck out of one side so it looks frosted. Opaque probably works better, though, if you can find it.
thesupplychick 10 years ago
Couldn't you use the frosted glass spray paint by Rust-Oleum or even plain white spray paint?
I bought it on Amazon and had it cut locally. But I suppose you could use regular glass (Dollar Store to the rescue) and spray it a matt finish on the back side. Or spray-mount a piece of wax paper to the back (or maybe even iron a piece of wax paper to the back??). Possibilities...
Oscelot 10 years ago
Good source of cheap glass: clearance frames at Michael's etc :3
love this instructable!
mdeblasi1 10 years ago
In re glass,
Martha Stewart has a nice etching cream that has very low odor and works in about 15 minutes.
You're not going to be able to etch deep shapes into something, but it will work for surface frosting.
I got it at Michael's in the US.
vtbeachldy 10 years ago
You can use clear glass or plexi and then spray mount some tissue paper on the bottom side. Anything that diffuses the light is good. If you use glass, you can use this unit to cut out stencils or other using a craft knife. (Plexi would scratch)
robchang 10 years ago
I love that desk, what kind of wood is it made of?
