CD Rack From Old CDs
Intro: CD Rack From Old CDs
This CD rack looks really good (if somewhat kitsch) and is not rocket science to make. You just have to measure stuff properly and be careful while you work, or, like me, you will have to start again three times.
STEP 1: What You Need
15 CDs
1 5mm threaded rob (usually sold in 1m lengths)
8 5mm hex nuts
5 5mm lock nuts
100 5mm rivet washers (usually sold in packets of 100)
1 20mm dowel stick
Permanent marker
8 5mm hex nuts
5 5mm lock nuts
1 20mm dowel stick
Permanent marker
STEP 2: Make a Template
Take one CD and mark a dot on either side of the centre hole, midway between the centre hole and the edge of the CD. Make sure one dot is about 1cm above the other one (take a look at the image to see how to mark it out).
With a 5mm drill-bit, drill two holes where youâve put the marks. This is the template for the rest CDs.
STEP 3: Drill Out the CDs
Take a stack of about three CDs at a time and, using the template, carefully drill out the holes. Make sure to set the drill on the slowest setting and drill very slowly.
STEP 4: Cut Threaded Rod
Once youâve drilled all the holes, cut the threaded rod into two 25cm long pieces with a hacksaw. File the ends of the pieces smooth with a file or some rough sandpaper.
STEP 5: Assemble the Rack
Now assemble the rack. Put the rods through once CD and put a hex nut on the one end. Now put 7 washers on each rod and then another CD. Every 5 CDs you can put a hex nut on and tighten the whole lot up, but be careful not to crack the CDs, like I did, twice. A hex nut is as wide as 2 washers, so you only need to put 5 washers and a hex nut on for every fifth CD.
Once youâve put all the CDs on, tighten it all up so that thereâs no play in the CDs or threaded rod.
STEP 6: Give It Legs
Now cut two 7cm and two 6cm pieces of dowel. Drill a 5mm hole 1cm from the top of each. These are the legs of the rack. You can paint them if you like.
Now attach the longer legs to the rods higher above the centre hole, using lock nuts. Do the same with the shorter legs. Now just make sure the whole thing stands straight and tighten the lock nuts.
24 Comments
jedii72 9 years ago
that's clever. nice job
a_tinkers_damn 11 years ago
georion 11 years ago
powerfool 12 years ago
But it's great idea! Thanks! I have tons of old cd's to use!
thepelton 12 years ago
lsmith254 12 years ago
ILOSN 15 years ago
jlb2458 15 years ago
uguy 15 years ago
randofo 15 years ago
killerjackalope 15 years ago
Grey_Wolfe 15 years ago
zpersichetti 15 years ago
FreshPineSent 15 years ago
GorillazMiko 15 years ago
Darkshot 15 years ago
Coffee bean 15 years ago
