CNC Cabinet Door Hack
Intro: CNC Cabinet Door Hack
I'm taking on the challenge of remodeling my kitchen. I've spent scads of hours torturing my brain trying to come up with a unique door and drawer front design, that I could accomplish in a reasonable amount of time. The hard part is coming up with a design you won't tire of. I hope you enjoy this little CNC project.
STEP 1: Why Hack Your Cabinet Doors?
I ordered a door sample from cliqstudios.com they seem to be of good quality at a reasonable price. But to me the design is same old boring styles and rails panel door I've seen in every kitchen since I was a child. Raised panel, flat panel, they are all the same. I have not figured out how to make the styles and rails unique yet, but give me a little more time. Once you get a rhythm going this project should go super fast.
STEP 2: Design and Cut Your Panels
I spent a number of hours designing the samples with Vectric Aspire using the create vector texture tool and the texture toolbox gadget. I used a 91 degree 1.5 inch v groove cutter to cut all the textures. you can see in the screen shots the approximate settings for a successful cut with that bit. It did take quite a bit of experimenting to get the samples I wanted.
My CNC router is a CRP pro 48 x 96.
STEP 3: Cut the Stock Panel Out of the Door
I used a 1/4" bottom cutting bit to cut the panel out of the door. just make a groove around the panel on the backside of the door and the panel will pop right out. The half inch or so lip will remain on the front of the door. If you do get tired of the design you can always change the panel again.
STEP 4: Set the Panels in and Admire
Set the panels in the door and decide which on to use. Once you have decided you can fasten the panel to the door with wood stops. Be sure to leave 1/16" clearance around the panel for to allow for expansion. Do not glue the panels in. Sample panels were made with OSB plywood.
3 Comments
charlessenf-gm 1 year ago
On TV TOH often features fancy smanzy kitchens in white. So, when the wife decided on white cabinetry, I went along with her choice (insisting on 'all wood' boxes and doors).
Experience should have told me that we are not 'white furnishings' types and certainly not in a kitchen!
Cleaning is a bee eye tee see aych and everything shows. If I could, I'd find simple flat panel inset doors and drawer fronts in a finish designed primarily for easy cleaning. The grease from cooking ultimately gets in the air and is deposited feet from the fry pan. On a smooth, flat surface, cleaning is possible - on such an intricate surface there is no way it can be cleaned short of refinishing!
Again, lovely work. Try it in the living room!
Modern Rustic Workshop 7 years ago
Very cool! The patterns on the inside of the cabinet could be absolutely limitless which I think is brilliant!
JörgenBörg 7 years ago
nice idea. cnc's can achieve a lot. and the best thing is that all doors will be the same :-). i keep that in mind when there is an old kitchen in my new house
