CNC Pen Lift
Intro: CNC Pen Lift
This instructable explains how to make a CNC pen-lift from an SG90 servo, two 4mm x 100mm nails, the spring from a ball-point pen, and a 3D printer.
The design accommodates pen diameters up to 14mm.
There is no pen-wobble when the pen is raised and lowered.
Construction is easy … all you need is access to a 3D printer, and basic workshop tools.
All STL and gcode files are supplied.
The estimated cost to build this pen-lift is less than $5.00 USD
Images
- Photo 1 shows the penlift attached to an experimental plotter
- Photo 2 shows a close-up of the assembled pen-lift
- The video shows the penlift in operation
STEP 1: Features
This pen-lift was inspired by https://www.youtube.com/watch?v=hkwSPbMtB84&list=PL3BbZZ9thFk58og0_ueqBFIlwoCzLGlwf&index=64
Significant differences include:
- Only requires a single bolt
- Uses a captive nut
- The V-shaped hole
- prevents round pens from twisting
- accommodates hexagonal pens
- The use of construction nails for the guides
STEP 2: The Servo Housing
The servo housing holds the servo and the two nails that are used for guides
The pen-up servo horn position is shown photos 4, 5, and 6
STEP 3: The Pen Holder
The slot in the side of the pen-holder takes an M4 nut.
Position the nut mid-way down the slot then insert an M4 bolt through the top.
Don’t over-tighten the bolt … a finger-twist is sufficient to hold the pen.
STEP 4: Assembly
Step 1
- Shorten the nails such that they will just protrude from the base of the servo housing (photo 1)
- Remove any ridges with a file
Step 2
- Rewind the ball-point spring around a nail
- It must be a loose fit
- Adjust its length such that it will push the pen-holder to the far end of the servo-holder.
Step 3
- Before inserting the nails into the servo-holder ensure that each side of the pen-holder slides freely under its own weight along a nail.
- This may require inserting a 4mm drill into the slider-holes to improve the fit.
- Don’t get carried away with the drill… any unwanted movement here will affect your plotter accuracy.
Step 4
- Insert one of the shortened nails through the servoholder, through the spring, through one side of the pen-holder, until it protrudes through the bottom of servo-holder (photo 3).
- The nail is a friction fit at each end of the servo-holder but the pen-holder should move smoothly.
Step 5
- Insert the other nail
- The nail is a friction-fit at both ends of the pen-holder but should pass freely through the holes in the pen-holder.
- Adjust the pen-holder hole sizes slightly if there is any tendency to stick.
- Done
STEP 5: STL Files
All STL and gcode files are attached
The STL and gcode files were created using Ultimaker Cura 4.13.1
STEP 6: Summary
Construction is easy … all you need is access to a 3D printer and basic workshop tools.
All STL and g-code files are provided.
Click here to view my other instructables.
11 Comments
anikilado 8 months ago
lingib 8 months ago
ghettobastler 1 year ago
Thank you for sharing !
anikilado 1 year ago
I used lingib's idea for the vertical guides, using two 4 mm diameter nails, and adding some brass tubing on the pen holder to reduce friction.
lingib 1 year ago
hmk42 1 year ago
(BTW, I guess you did use FreeCAD 0.20, 2.0 does not exist.)
lingib 1 year ago
Thank you for your interest in my project :)
For some reason the Instructables website refuses to upload "zip" and "FCstd" files.
Private message me with your email address and I will send you a zip file containing all files.
Thanks for the heads up on the typo ... it's now fixed
Palingenesis 1 year ago
lingib 1 year ago
