CNC Pen Lift
Intro: CNC Pen Lift
This instructable describes a low-cost CNC pen-lift that:
- accepts different diameter pens,
- supports different pen angles,
- is precise,
- and extremely sturdy.
Only two 3mm bolts are required to attach it to the plotter described in https://www.instructables.com/id/CoreXY-CNC-Plotte...
Photo 1 shows a fibre-tipped pen attached vertically by means of two small "tool clips"
Photo 2 shows a self-inking water-color brush attached at an angle by means of a large "tool clip".
STEP 1: Design
The simple pen-lift shown in photo 1 has five disadvantages:
- each pen diameter requires a new custom fitted bracket.
- the pens are prone to wobble as they won't drop if there is friction.
- a new pen-lift collar is required for each pen size
- different pen angles are not supported.
- pencil traces are faint.
Solution to problem 1
What we need is something that automatically adjusts to the pen diameter.
Believe it or not such a device exists in the form of spring-metal "tool clips". These clips come in a range of overlapping sizes:
- 10mm tool clips are suitable for pencils.
- 13mm tool clips are suitable for sharpies and watercolor brushes.
Solution to problem 2
Eliminate the source of wobble by attaching the pen to a friction-less sliding plate.
This is achieved by attaching a tool clip to one side of a metal plate and four V-groove pulleys to the other. The pulleys allow the plate to move up and down a vertical Z-rail attached to the plotter.
Solution to problem 3
Eliminate the need for different size pen collars by bending the top of the plate ... one size now fits all.
Solution to problem 4
The tool clips are held in place by means of a single nut and bolt ... simply angle the center tool clip.
Solution to problem 5
This problem solved itself ... the extra weight from the tool-clip(s), metal plate, and V-groove pulleys ensures that all pencil lines are clearly visible.
STEP 2: Parts List
The following parts are required:
- 4 only V624ZZ V-groove pulleys [1]
- 1 only 80mm x 40mm piece of 18 gauge aluminium sheet [2]
- 1 only 10mm x 3mm x 60mm length of aluminium extrusion [3]
- 6 only 3mm bolts
- 2 only 3mm nuts
- 2 only 9mm threaded nylon spacers
- 2 only 10mm tool clips [4]
[1]
The V-groove pulleys are available from https://aliexpress.com in packets of 20. You should have 4 pulleys left over if you built the plotter described in https://www.instructables.com/id/CoreXY-CNC-Plotte.... The remaining parts may be obtained from a hobby shop or hardware store.
[2]
Instructable https://www.instructables.com/id/How-to-Cut-Fold-S... describes how to cut and fold aluminium sheet.
[3]
18 gauge aluminium sheet is less rigid but may work as a substitute.
[4]
Large pens may require 13mm tool clips.
STEP 3: Construction ... the Z-rail
Two 3mm holes were drilled through a 60mm length of 3mm x 10mm aluminium bar using the drawing template shown in photo1 .
Two 3mm holes were then drilled into the pen-carriage assembly using the holes in the above bar as a template.
9mm threaded nylon spacers were then attached to the pen-carriage assembly using 3mm bolts.
The Z-rail was then bolted to the spacers as shown in photos 2 and 3.
STEP 4: Construction ... the Slider
Cut an 80mm x 40mm strip of aluminium sheet using the the method described in instructable https://www.instructables.com/id/How-to-Cut-Fold-S...
Drill and fold the aluminium as per the template shown in photo 1.
Mount four V-groove pulleys as shown in photo 3. If necessary elongate the 4mm holes on one side of the Z-rail to obtain a perfect fit.
Bolt a tool clip to the center hole and attach your pen. The extra tool clip shown in the opening photo isn't really required but ensures that the pen doesn't move when doing complex plots.
Click here to view my other instructables.
22 Comments
creativerobo1602 9 months ago
lingib 9 months ago
Motor windings comprise two coils. Use an ohm-meter to find the coil ends.
Label one set A ... label the other set B.
My plotters use Big Easy Driver motor controllers which have four pins labelled AABB
Connect the A leads to the A terminals on the Big Easy Driver. Connect the B leads to the B terminals on the Big Easy Driver.
If the motor runs the wrong way reverse the motor connections.
jeremy.green 3 years ago
JohnRow 2 years ago
jeremy.green 2 years ago
JohnRow 2 years ago
JohnRow 2 years ago
lingib 2 years ago
I got my bearings from https://www.aliexpress.com/.
You should be able to eliminate the wobble if you fit two V-pulleys to one side of the L-bracket and slightly elongate the remaining holes towards the fixed pulleys.
When mounting the remaining pulleys press each towards the opposite fixed pulley when tightening the nuts.
Before mounting, finger tighten each of the pulley backing-nuts such the the pulley spins freely without any wobble.
CityZenToo 5 years ago
lingib 5 years ago
jeffreywolberg 6 years ago
lingib 6 years ago
The pen-lift is attached to my CoreXY plotter described in https://www.instructables.com/id/CoreXY-CNC-Plotter/. The software for this plotter may be downloaded from step 3.
The radial test pattern shown in the video uses the built-in test menu.
paulmat 6 years ago
Keep up the posts! I've been following your builds just waiting for some free time to actually try one out (too involved with a whole house reno right now and have a Shapeoko3 to play with anyhow). Thank you for the detailed builds!
lingib 6 years ago
Now there's a thought ... a house painting robot ;)
paulmat 6 years ago
actually, I'm using the Shapeoko to custom cut cedar shingles, no need for paint!
voxelator 6 years ago
lingib 6 years ago
Thank you :)
tittiamo68 6 years ago
For my mini plotter, I used a piece of PVC pipe and two screws.
Hello
Tiziano
lingib 6 years ago
Your PVC pipe and discarded drive is a clever solution. Thank you for sharing :)
My sliders cost next-to-nothing so I have made several and simply leave the pens and brushes attached. This allows rapid pen/brush changes without the need to reset their heights/angles every time I make a change.
