Calculating Frog: Make Your Own Mechanical Calculator (unpublished)
Intro: Calculating Frog: Make Your Own Mechanical Calculator (unpublished)
Since writing this instructable I have revised the project and no longer feel that the tutorial I published is the best way to make this calculator -- it was way too complicated, cutting up a metal tea box, etc, etc. Unfortunately, since the instructable had been entered into a contest, I cannot delete it. Instead I have deleted the steps (except for this introduction). Apologies for the inconvenience... If you like this frog, a different template with alternate instructions is available on my website. I promise, at some point, I will re-write this instructable with a free PDF just for instructables.
In grade school kids are taught about math "triangles." 3+4=7 or 7-4=3 or 7-3=4 for example. The same principle works with multiplication and division (3x4=12 or 12/3=4 or 12/4=3) By putting each number on the angle of a triangular flash card and by hiding one of the three corners, not only are children practicing memorization, they are grasping the concept that addition and subtraction or multiplication and division are like the flip side of the same coin. They can literally see the relationship.
My mechanical calculator is based on this triangle, but by using simple mechanics the triangle formed by the frog's feet and his clasped hands can move. A single card will show the whole multiplication table, and watching it move around is a whole lot more fun than flashcards.
I should say that I did NOT come up with the concept: William Robertson, in 1916, designed a tin toy he named the "Educated Monkey." When I fist saw it a few months ago I thought it would be fun and easy to reproduce the idea on paper -- I was dead wrong.
My desk has been strewn with pins and frog body parts for weeks as I've been trying to fine-tune the template. Changing the monkey into a frog was easy and natural; the way the creature moves is much more frog-like than monkeyish. Getting everything to line up properly was a bit tricky, but manageable. I was able to improve Mr. Robertson's design by figuring out a way to display when a number is multiplied or added to itself (i.e. 5+5) He just drew a little square which represents the number, but my template shows the actual number (you can't see me right now, but I just patted myself on the back). I found tiny aluminum eyelets at a paper supply store, but during the design process, for expediency, I used pins sticking up and tried not to injure myself as I banged my desk in frustration... Because after getting everything to work perfectly, when I finally printed my frog out in color, cut the pieces for what I thought would be the last time and used the cute little eyelets --- it didn't work. The pins I had been using held the paper body parts in place while allowing them to pivot freely. The eyelets, on the other hand, held the paper together too tightly, so in a few critical places instead of pivoting the paper stuck and buckled instead. The d... thing needs to be made with a stiffer material after all.
25 Comments
JuergenW1 5 years ago
And here is my reproduction of that design, but its a monkey, not a frog
https://www.thingiverse.com/thing:2891426
belsey 5 years ago
perfo 8 years ago
Hello, I like the idea. I can't seem to find the actual instructable though. How many steps are there ?
Where would I find the details on how to make one ?
Thanks...
belsey 8 years ago
MicioGatta 9 years ago
Thsi is genial!
DUO0037 10 years ago
HollyMann 12 years ago
biomech75 12 years ago
nead 12 years ago
Reminds me of the pantograph I had when I was very little.
Wonder what else this could be used for.
Thank you for sharing.
nead 12 years ago
We will try again using a donor cookie tin.
belsey 12 years ago
mikecraghead 12 years ago
Here's "Consul the Educated Monkey," the little dude in the red suit from 1916: http://www.officemuseum.com/kids.htm.
My kids had a modern spinoff, here's one (of many) stores selling it:
http://www.huntarcompany.com/mm5/merchant.mvc?Screen=PROD&Store_Code=&Product_Code=50201&Category_Code=MKL
...I was always impressed with the engineering of the thing. I wonder if it would be easier or harder to make with the arms over his head than under?
Anyway, well done!
belsey 12 years ago
mikeasaurus 12 years ago
Though, is it weird my first thought after seeing the video was this classic cartoon?
belsey 12 years ago
GASSYPOOTS 12 years ago
zomfibame 12 years ago
AngryRedhead 12 years ago
halmars 12 years ago
I have read the end part where you say paper and bent paper clips will do, so once I get a printer up and running I'llhave a go at this. Thanks
belsey 12 years ago
