Catamaran Stand Up Paddle Board (SUP)
Intro: Catamaran Stand Up Paddle Board (SUP)
This is a fiber glass catamaran stand up paddle board or simply SUP. SUP boards are more related to a boat like construction rather than a surfboard. The sport of stand up paddle boarding came about in the era of surfing. It is a much larger board used along with a paddle in a standing fashion, to explore, race or surf. The shape and weight will be more determining of what the board is suitable for. This particular model I designed for a fast, long distance, touring style. My board is 12'6" long by 28" wide and weighs around 30-32lbs. The catamaran shape is great for a more stable board. I have not surfed with it as of yet and it is not suitable for a race that has many turns due to the lack of surface area in the rear (the method used to turn a sup is shifting the weight to the rear, raising the nose). Hope you enjoy! Btw: Eventually I would like to create these completely hollow. If you like what you see, I would appreciate any help. Below is a link on how you can help. Thank You!!!
STEP 1: Foam
Buy Blue insulation foam. Panels are 4x8 feet and about $14. You will need 3-4.
STEP 2: Cut Foam
Once you have traced a design you like, sketch it on the foam. Measure twice cut once!!
STEP 3: Place Pieces Together
Before any glue is used, place the pieces together to make sure they fit correctly.
STEP 4: Glue
I used water resistant glue since it will be glassed later anyway.
STEP 5: Cut Upper and Bottom Parts
Once the basic shape is glued and pieced together you will need to make the top and bottom of the pontoons.
STEP 6: Glue
Once it is fitted and glued. Begin shaping. I used 150 grit sand paper.
STEP 7: Second Pontoon
Repeat the steps for the second pontoon.
STEP 8: Middle Piece
Join the two pontoons.
STEP 9: Deck
Add a deck to stand on.
STEP 10: Shape
Shape using sandpaper. Take your time.
STEP 11: Get Rid of 90 Deg Corners
I added a rounded edge underneath to ease with glassing.
STEP 12: Glassing
Add fiber glass. Use two part epoxy.
STEP 13: Add Fin Boxes
After adding 2-3 layers of fiber glass prepare fin boxes. Research angles for the size you are building. Also add any leash holds or net holds at this time.
STEP 14: Paint
Design a color scheme and begin painting base color first.
STEP 15: Design
Continue with your design scheme. I chose a post apocalyptic look.
STEP 16: Glass/epoxy
You can finalize with a thin 4oz fiber glass to seal the images or glass with epoxy alone. Add the epoxy with a brush and add 3 layers total. Let the epoxy sit for 3 hours exactly before its cured to add the next layer.
STEP 17: Help Support Us!!
ATTENTION EVERYONE!! I have launched a small campaign to fund my company PH822 Composites & Design. Please checkout the link below for a chance to purchase a high quality T-shirt with my logos on the front and back. I have 21 days to meet my goal of 282 shirts (but I can go above)!!!!! Please share at the very least!!!
teespring.com/makusup
47 Comments
jocrow1996 2 years ago
jjmitchell 3 years ago
Did you ever make a hollow SUP? I'm getting ready to make a catamaran style SUP plug and mold for the top and bottom so I can make multiple boards. Your board looks great!
vakrepulo 7 years ago
Hi
I have a few questions:
What kind of fiber glass did you use? (I mean: How much the weight of it?)
How many layers of fiber glass did you use?
thanks, vakrep
JefferyC9 7 years ago
So did you vent it? Seems like it might explode being hollow like this. Did you ever get a solid weight range figured out on this. Surely with the volume dimensions and lack of weight it would hold in the 200lb range.
The only question I really have is what did you use for glue and how many tubes did it take? I've heard gorilla glue works well for this application and comes in tubes. Is glue expansion not a problem with the flexibility of the foam?
mayala6 8 years ago
mayala6 8 years ago
LarryD16 8 years ago
LeslieP7 8 years ago
Now this is pretty cool. This is the first I ever ever seen designed like this. If this works, I'm sure it will be the next "big thing" on the water.
I just purchased a SUP from http://www.surfoutfitter.com. They may be contact for you if this Catamaran SUP works.
Good Luck!
mayala6 9 years ago
mayala6 9 years ago
paracorded_inspirations 10 years ago
C_B 10 years ago
pintoc2 10 years ago
mayala6 10 years ago
PaulLee97 10 years ago
nate_hartzfeld 10 years ago
