Charlieplexed Row of LED Lights, for the Arduino
Intro: Charlieplexed Row of LED Lights, for the Arduino
This is my instructable on charlieplexing a LED row/string with the arduino. I noticed that there weren't many instructables on charlieplexing using an arduino, so i made this. I tried to keep the project simple, but that didn't work very well. The soldering is complex, I wouldn't recommend this as a first time soldering project.
Here's some background on charlieplexing: en.wikipedia.org/wiki/Charlieplexing
I took about 80 pictures & not all of them made it into the main steps, but you can find them in step 9: Extra Pictures
If you have any comments, questions &/or suggestions please ask them!
STEP 1: Parts List:
Parts:
- 12 LED's; I'm using some 3 mm Red LED's
- 4, 270 Ohm resistors; You can use other values as well
- Perfboard/Veroboard; I used a piece 27 holes x 5 holes
- Wire; I used some 26 gauge, solid core wire
- Header pins (optional)
- Arduino
Tools:
- Soldering Iron
- Hot glue gun (optional)
- Helping hand (optional)
- Arduino
Tools:
- Soldering Iron
STEP 2: Solder the Anodes of the LED's
There's not much to say about the next few steps, but there's a few main points I'll mention.
- The LED's anodes are soldered in groups of 3
- Make sure the 4 groups don't get joined together, but stay separate
The wires that connect the 4 groups are kind of shaped like a L.
STEP 3: Bend the Cathodes
Main Points:
- You should end up with 4 different rows
- Make sure each of the the 4 rows contain only 3 connections to the cathodes & only one from each group of LED
STEP 4: Solder the Cathodes
Main Points:
Not much to say here just solder the 4 rows & make sure to avoid any bridges in the wires. You should have 4 rows that have only 3 connections to it, one from each group with one group not attached. I tried to make the schematic as close to the wiring as possible, so that might make what I'm talking about a little easier to understand. It's is the last picture on this step.
STEP 5: Install Resistors
This is a little confusing. Hope I explained it well enough. There are more pictures of this in step 9.
Resistor end connections:
1) One end connected to row 1. The other to group 4
2) One end connected to row 2. The other to group 3
3) One end connected to row 4. The other to group 2
4) One end connected to row 3. The other to group 1
STEP 6: Add the Control Wires
This is probably one of the easiest steps! All you are doing is soldering wires to the 4 groups.
I used some pieces of wire about 6 in long. They don't have to be different colors but it can be helpful if anything goes wrong & you need to debug the circuit. You don't need some header pins, but if you want some feel free to use them.
STEP 7: Coding the Arduino
Here's some basic steps to program your arduino.
1) Download the source code from below
2) Open the file in the Arduino IDE
3) Press the "Upload to I/O Board" button
4) Once the program is uploaded it will start running
Note:You may need to change a few things in the "const int ledPins[12][2] ={" array if the led's turn on, out of order.
I tried to add a good amount of comments to the code, but if you have any questions, please ask them.
STEP 8: Have Fun!!!
This shouldn't be to hard, but it might be
STEP 9: Extra Pictures
Well, I'm not sure if I when a little overboard with the pictures, But here's the rest of the pictures if you need something clarified. If you have any questions feel free to ask them.
Pictures 1-9: Installing the LED's
Pictures 10-13: Bending the cathodes
Pictures 14-18: soldering the cathodes
Pictures 19-20: Installing the resistors
Pictures 21-23: Installing the control wires
38 Comments
phenoptix 12 years ago
Charlieplexing.
My plan is to have play with the code to see if I can improve the bounce of the larson, and perhaps port it to an ATTiny rather than monopolising an Arduino!
Great instructable by the way. Having a look at your new ones now!
pglasspoole 12 years ago
Additionally, you both use pin 1, 2, 3, 4 in your schematic and then use 0, 1, 2, 3 in the code.
Lastly, neither of these schematic allow the program to work in all three modes.
Am I missing something or was this just a very poor example of charlieplexing. It is complicated enough without getting contradicting info.
The instructable is a really good example of charlieplexing and helped me a lot. It's not the only resource I used to understand the concept.
646826 5 years ago
Best image scheme. I did not find 5 pin same scheme, can you help me?
ChathurangaW1 7 years ago
i done this by using Arduino and 10 LEDs
watch Video : https://www.youtube.com/watch?edit=vd&v=jDdvyJ55Z2s
AnkitS139 7 years ago
Error solved ty
I'm connecting led strips instead of led's. For number 1 strip pin configs are pin1 high and pin2 low and for 2nd strip, pin2 high and pin1 low. These two pins are clashing with each other. Can anyone suggest me the way.
m10us44 9 years ago
In file included from sketch_apr27a.ino:1:0:
sketch_apr27a.ino:48:21: error: variable 'displays' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
Fout bij compileren.
ChristianM64 8 years ago
I googled the message and found a fix here: http://forum.arduino.cc/index.php?topic=254424.0
In front of this one line
byte displays[][12] PROGMEM ={...
add 'const'.
const byte displays[][12] PROGMEM ={...
It compiled and was able to be sent to the Arduino. Now, my LEDs are out of order, but, I'm making progress! =)
I'm getting the same message.
furri 10 years ago
Vick Jr 13 years ago
ardor 13 years ago
The Arduino uses 5V not 3 so you do need the resisters.
Your christmas tree leds either have resistors in them somehow, are a higher voltage or... Shrug, you got luck somehow...
facilitator476 12 years ago
bakabr 11 years ago
OCPik4chu 11 years ago
sarath12445 13 years ago
Rich1953 11 years ago
Robot Lover 13 years ago
