Checkerboard Table
Intro: Checkerboard Table
This checkerboard table is made from maple and walnut wood.
STEP 1: Strips
Strips of wood were cut from maple and walnut. Alternate each strip, one maple, one walnut. Glue the strips together. You can use a size that is the best fit for your checkers. Standard, small, or large.
STEP 2: Making It "checkered"
After strip were glued together, cut across the strips. Every other strip was then flipped and glued to give it the "checkered" look.
STEP 3: Sanding
Sand, sand, sand to get it as smooth as possible. Then walnut was chosen for the the frame to surround the checkerboard.
STEP 4: Framing
After measuring, cut the frame. Glue and clamp.
STEP 5: Slats
Cut slats that will support the checkerboard. Glue and use screws to secure.
STEP 6: Add Checkerboard
Drop in the checkerboard and glue. Let dry overnight.
STEP 7: Legs and Support
Attach legs by using screws and a Kreg jig. Support boards will help make it more sturdy.
STEP 8: Finish
Apply several coats of clear coat to get your desired sheen.
STEP 9: Completed Checkerboard
Enjoy playing a game of checkers on your newly completed table.
3 Comments
jgscott987 7 years ago
That's a good looking project. Curious why you set the checkerboard below the surface of the rest of the table.
varmitwife 7 years ago
It keeps the checkers from falling off the table, especially if you have younger kids playing. Actually thought it enhanced the appearance, also.
mrsmerwin 7 years ago
I noticed you had sunk the playing surface. I thought it was just a nice look. I like that it is functional too. If you have it recessed enough, you may be able to place a plexiglass cover over a game in progress.
