Chewing Gum USB !!
Intro: Chewing Gum USB !!
Welcome to another of my awesome USB case mods !
This case mod allows you to sneakily conceal your USB in a chewing gum packet, apart from being super-mega-awesome-cool this mod will stop all those annoying classmates who always borrow your usb, (you know, the ones that don't delete their files afterwards)
When they ask simply reach into packet and retrieve your "chewing gum" !!
This is really easy and the finished product can be achieved in around 10 min !
Hope you like it !!
Hope you like it !!
STEP 1: Obtaining USB, Cardboard, Gum !
Well its obvious, but for this project your probably going to need a USB
My USB had already lost its case (hence the 'ible) so i didn't need to remove one.
If your USB is still i its plastic coffin then grab a craft knife and gently pry at the edges, this will pop the little clasps, now slowly lift the top and it should also pop off.
For this 'ible you will also need a section of cardboard approximately 4 inch by 4 inch.
Surprisingly enough you will also need a pack of Chewing Gum !
Onwards to step 2 !!
STEP 2: Cutting the Cardboard
Ok now we have the materials we can start making the case.
Rest the Gum packet on the cardboard and using a pencil draw around it. Now remove the Gum packet and using a craft knife cut along the lines you drew
(dont cut your nice wooden desk though, if you do, using a dremel to try to buff it out DOESN'T work, it gets much, much worse) :(
STEP 3: Packet Surgery
Now we have the cardboard we need to open up the packet.
We don't want to tear it open so grab a craft knife !! NOT by the SHARP bit !! oh jesus go get a plaster, and then follow the pictures for more detail.
STEP 4: Dividing Forces
Now you have cut the packaging you need to size up and cut the cardboard so it will fin in the body and cap sections.
STEP 5: Fitting the Usb
You cant just shove the USB between the cardboard so we need to use our craft knife careful now to hollow out.
Cut the top layer of the cardboard off and then place the USB in the hole, if it doesn't fit cut out more space.
When you have the right size hole use some glue to attach the two sides of the cardboard together.
STEP 6: Fitting Into Pack
Because you measured the cardboard before you cut it at the beginning it should slot right in to the empty packaging. if it doesn't, use your craft knife to cut little bits off the edges until it fits.
When the cardboard does fit put a little bit of glue on the outside so that the packaging wont slide off.
STEP 7: Finito Completo !
Let out a yelp of joy because you have now finished the USB Chewing gum case mod !
Thanks for making/reading my instructable, i hope you liked it !!
Leave a comment and tell me what you think !
Wondering what to do next ??
Check out my other USB mods !
Shotgun Shell USB
Champagne Cork USB
Or one of my other 17 instructables !
CLICK HERE
Shotgun Shell USB
Champagne Cork USB
CLICK HERE
52 Comments
Maanav. 7 years ago
StanleyK8 7 years ago
Sweet!
Trojan Camel 8 years ago
awesome!
Mixey 101 9 years ago
now i need gum and have to make this , cool idea :)
canem 9 years ago
Pretty cool idea !!!!
gšapkinas 9 years ago
great idea
tmaus1 9 years ago
thaliquid 9 years ago
nredinger 9 years ago
jkleidon 9 years ago
loompiggytutorials 9 years ago
Eldalote 9 years ago
This is awesome!!
USAcalc 10 years ago
and make sure u dont get confused between witch gum pack is witch I am sure no 1 wants to eat a flash drive instead of gum
LOLOLOOLOLOLOLOLOL!!!!!!!
dfalk 12 years ago
Danny_Payne 13 years ago
hcaz-301 13 years ago
rotfltechnology 13 years ago
DarthMonkey 14 years ago
or badly injure you because i was thinking about making one and i think i have changed my mind
=SMART= 14 years ago
If you cut yourself with the knife it could hurt but everyone know that, the usb is totally safe it cant give you an electric shock
dude300 13 years ago
