Chocolate Dinosaur
Intro: Chocolate Dinosaur
This instructable will show you the process for how I made my valentines gift, a chocolate dinosaur (holding a flower / anything). It was fairly simple, but quite time consuming, and difficult to make without her noticing... I didn't realize until this instructable that I may in fact have a dinosaur fetish (weird)
STEP 1: Make a Dinosaur!
I started by creating a 3D cardboard dinosaur template using just my imagination, a marker, an x-acto blade, and some cardboard. I cut out several pieces of cardboard to create a (somewhat) rigid dinosaur of cardboard. Don't spend too much time on this step, it isn't that important, a crude model will work just fine.
STEP 2: Make the Mold
Next, I decided for no reason, except that it sounded good, to saran wrap / tin foil wrap the dinosaur model. In retrospect it was not necessary but may have helped slightly (it didn't take too much time either).
Next, I paper mache'd the model thickly. (sorry for the lack of pictures here)
STEP 3: Hollowing the Mold
to make it a mold that allows for the inside to be chocolate, I had to cut apart my paper mache dinosaur and remove the insides (yum). To do this I used an x-acto blade to cut along the spine and various other places (use as few cuts as possible, see my pictures). I then re-attatched some of the cut off pieces.
I also duct taped the inside and some of the outsides to make it smoother and so that less material would transfer to the chocolate when completed.
STEP 4: Melt the Chocolate
Now the fun part :)
Keep in mind that any chocolate that drips during this step is fair game for eating :)
Start by melting the chocolate (you can find other 'ibles on doing this). It is important to remember to be patient, melt the chocolate on a double broiler, on low heat, and also don't let water get into your chocolate!
I used more about 8 pounds of bakers chocolate which I found on sale for a dollar per pound (my lucky day).
Ready to pour?
Ready to pour?
STEP 5: Pouring
This was the tricky part.
To do this part I used whatever I could to prop the pieces while I poured molten chocolate into them. I started with the four separate parts, shown in the previous step, and would pour the chocolate and then shake a bit and then let them individually harden in the freezer.
When I had all 4 parts each completed, I would tape over the connection between molds (leaving a small hole on top to pour through, I held them over the stove for a bit to let them melt just a bit and then poured more chocolate in between the molds. I wasn't sure if this would work, but my dinosaur seems to hold really stably together. I connected the two halves of the body first, then the tail, and lastly the neck / head.
STEP 6: Finish!
Finally, with all the mold parts together, I had to cut off all the undesired paper mache and duct tape. I wasn't sure how hard or easy this would happen... it wasn't too hard but it was kinda tedious and messy (poo). After taking it all off, I shaved sections off that looked bumpy or bad, or I would melt them into smoother sections, or even add chocolate with my finger where I thought it was necessary...
I plan to put a flower (or two, three, four hundred and eighty...) in the dinosaurs mouth, but I will wait until tomorrow evening to go get that...
hope she likes it :)
This instructable is entered in the Dinosaur Contest! (this is a really cool contest that deserves more participants, check it out!)
26 Comments
Velociraptor uwu 3 years ago
Foaly7 13 years ago
dramioneforinfinity 14 years ago
luvit 14 years ago
Onyx Ibex 14 years ago
zascecs 14 years ago
Wasagi 14 years ago
watermelonhead 14 years ago
Lance Mt. 14 years ago
mahljh 14 years ago
b-stro 14 years ago
b-stro 14 years ago
sarahfish 14 years ago
mrfoltz 14 years ago
I wonder if you could use bakers silicone the talk about on "the Cake Boss" ???
mikeasaurus 14 years ago
jessyratfink 14 years ago
