Chocolate Extruder for Ultimaker
Intro: Chocolate Extruder for Ultimaker
This project is to build a chocolate extruder for custom made Ultimaker. The idea is to use a heated syringe to extrude chocolate.
STEP 1: Chocolate Hotend
We use 20ml syringe. The inner diameter is 20mm. Syringe is covered with aluminum foil, then Kapton tape. The heater is made of NiCr wire coiled on covered syringe and itself covered with Kapton. To get uniform temperature on the syringe we add layer of aluminum foil and Kapton outside the heater. And install the NTC 100kOhm Thermistor.
STEP 2: Firmware Configuration
The configuration is not a big difference from standart 3d printer.
1) Steps per mm for extruder. We use 1/16 microstepping and 1.8° Nema 17 stepper, so to move 1 mm of syringe we need 4000 steps, but for easier use we recalculated it to make 3mm filament diameter instead of 20mm syringe. So we got 90 steps per mm.
2) Temperature. We made Mintemp = 20°C, and preheat temperatures 30°C.
3) Extruder endstop. We don't have it.
STEP 3: Chocolate Extruder V1.0
Ok, we have a heated syringe with thermo control, but we need to press the chocolate through the nozzle. That is why we need a feeder (or press). For this we use M5 threaded rod and nut, 5x5 flexible coupling, 2 fluoroplastic bushings for less friction and two 8mm shaft rods.
STEP 4: Chocolate Extruder V 1.1
After testing we found that 2 bushings are not enough, so we made the compressing part 3 times higher and added two more bushings. Then we found that flexible coupling is extending because of high load, so we added a bearing to fix upper part of threaded rod and two nuts to prevent coupling from extension. Also we have broken the thermistor's wires, when mounting the syringe, so we replaced all wiring out from the mounting clipses.
STEP 5: What Chocolate to Use?
For first tries we used the cheapest milk chocolate from the nearest store. As the result it was melted easily (30°C), but after extrusion it stayed melted for about an hour, under the big cooler (120mm 220v). This is not a good way to print something. So we bought a dark chocolate and it was melted harder but just a bit (35°C). But these temperatures are about 3°C less than actual temperature of chocolate inside. Then we waited untill all air bubbles would come out of the syringe and only then insert the piston. Then we waited untill the temperature would drop to 26°C meaning 29-30°C inside or a bit higher. the result was much better but not perfect. So we need to add more cooling, but if the flow would be high it would just blow the chocolate off the place and the object would be broken.
STEP 6: How to Load Syringe
To load a syringe you need to broke the chocolate bar in small pieces and put them into the syringe. It should be heated to about 40°C and wait untill it melts, pressing it with something. The syringe should be full of chocolate before inserting piston.
STEP 7: Extreme Cooling
To cool the chocolate we had to move the printer outside. It is winter and the temperature is about -4°C. And it really improoved the quality of the print. The main problem we had was to start the print. chocolate was cooled inside the nozzle before the printing was started. So we started the print inside and during the first layer moved it outside and...prinded a cool bunny =)
10 Comments
ernesto.restrepo40 4 years ago
Please could you draw the circuit for making the heater. What voltage can I use ?
antoniomatar 5 years ago
140103087 6 years ago
rigvedhattekar 7 years ago
share the CAD files or stl files of the body
gtoal 7 years ago
maybe make a bed of peltier chips for surface cooling without a breeze?
JayWeeks 7 years ago
I'm glad you included that comment about what chocolate to use. I would have never thought of that.
Make Zone 7 years ago
I like cats 8 years ago
cool, but I don't get it
Sajjad_A 8 years ago
That is really cool. You should try and sell these designs to restaurants or pastry shops... :)
DIY Hacks and How Tos 8 years ago
Nice! You could make some awesome desserts with that extruder.
