Christmas Snowflakes Decorations With Laser Cutter!
Intro: Christmas Snowflakes Decorations With Laser Cutter!
After taking the Laser Cutter class at Techshop, I have been playing around so much, it is so addictive!
My girlfriend asked me to make "something useful" and I came up with this ides for Christmas Decorations: needless to say, my girlfriend was ecstatic!!!!
...and it is sooo easy!
Tools needed:
Laser Cutter (duh!)
TechShop Membership (Duh!)
Caliber
Tape
Orbital sander
Belt Sander
Material needed
Wood scraps
Wood panels
Tools needed:
Laser Cutter (duh!)
Caliber
Tape
Orbital sander
Belt Sander
Material needed
Wood scraps
Wood panels
STEP 1: Getting the Templates
The first step is getting the templates and import them into Corel Draw.
A snowflake can be pretty complex to draw from scratch, especially if you are not so good on drawing, and I am not!
This is where some "creativity" and "resourcefulness" comes handy!
I was surfing on Epilog website and I noticed a link: "Sample Club" and there you can find lots of useful templates and ideas!!!
Among them, here's the ones we will be using: Snowflakes
Follow the instructions and open the files in Corel Draw: We will be using the "sc_snowflakes_glitter.cdr" and "sc_snowflakes_wood.cdr"
The files are already in .cdr format, so, no conversion will be necessary
STEP 2: Testing
You want to use some cardboard or wood scraps and do a test run before using that nice piece of wood you just bough!
At Techshop you can find lots of scraps that can become very handy!
I used a piece of cardboard and a wood scrap.
You need to carefully set the speed and the power so that the laser goes all the way through the material, otherwise you will have to either re-run the job, with the risk of having the piece not re positioned correctly, or use a knife to cut through the uncut lines. Follow the instructions you got when you took the laser 101 class at Techshop and, in case of doubt, don't hesitate to ask a Techshop staff member or a fellow DIYer!
An alternative to the knife is to use the orbital or the belt sander (tricky with small parts) to grind down the few hundredth of inch on the backside: I learnt that this is a very useful way, but you need to learn how to master it (but hey, TECHSOP is here for this, right???)
The snowflakes coming from the wood scrap were actually so good that I decided to keep them!
STEP 3: Get Down to Business
Ok, now that you tested the project, you can use the more complex shapes contained on the "sc_snowflakes_wood.cdr" file.
Just set the document size, fit the snowflakes in and print!
The results will amaze you!
And you can find tons of on-line templates, just google for pictures "Christmas decorations", and select "line drawing".
Then, when in Corel Draw, just use the function "bitmaps" -> trace and voila'!
STEP 4: Acrylic Snowflakes
Of course, acrylic is as simple as wood, and the results are, to say the least, mesmerizing!
3 Comments
gviale 11 years ago
gviale 11 years ago
randofo 11 years ago
