Clean a Knife
Intro: Clean a Knife
In this instructable, I will show my way of easily cleaning a hunting knife, swiss army knife, whittling knife, etc... Remember to give me a +1!
STEP 1: Long Lasting Blade
First thing, after using a knife and it gets dirty, don't close it (if its a closing knife). The reason is because stuff like dirt, tree sap, what ever is on the blade might get stuck in the base of the knife, dulling the blade every time it is closed. This will assure your knife a long happy life. The picture is of my knife after doing my other instructable, Whittle a Staff / Walking Stick.
STEP 2: Hot Water
Turn a tap on hot and wait for it to heat up. Once it is as hot as it gets, place the blade under the water for 30 seconds, rotating it.
STEP 3: Electric Tooth Brush
Take an old electric tooth brush, and brush all along the blade, with some pressure. Do the same thing with both sides.
STEP 4: Rinse
Rinse the blade the same way you did in step 2, to make sure it's immaculately clean.
STEP 5: Dry
Dry the blade with a towel making sure that the sharp edge is facing away from the towel, not towards. Any make SURE that the blade is fully dried.
STEP 6: Done.
Your blade should now be as shiny as new! Remember to give this instructable a +1!
38 Comments
paracordry 10 years ago
thatsjet 11 years ago
owlart101 12 years ago
scottrules 12 years ago
Arbitror 12 years ago
dirt action julian 12 years ago
colorex 12 years ago
https://www.instructables.com/id/Popsicle-Stick-Swiss-Army-Knife-Prop/
Good instructable!
_noth_ 15 years ago
adamvan2000 14 years ago
Polishing Peanuts 12 years ago
LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.
Sure, it is only a light lube and no where near as good as machine oil but still, WD40 will do in the field.
cobalt420 13 years ago
fartnocker 14 years ago
before this i opened up all the tolls on my swiss and put it in the dish washer.
Thanks!
Patented 14 years ago
TheDevilsRubberDucky 14 years ago
Arbitror 14 years ago
lilpepsikraker 14 years ago
aaaltomare 14 years ago
Nice tutorial on cleaning! You can use a little dish detergent to help get those particularly nasty stains and grit off. Also - after washing any knife you should use a little 3-in-1 for lube.
