Clean a Knife
43,965
88
38
Introduction: Clean a Knife
About: One of my favorite hobbies is dismantling electronics, then either combining them together to create something new, or adding components to make them better. I also like gadgets, whether it's taking them apart…
In this instructable, I will show my way of easily cleaning a hunting knife, swiss army knife, whittling knife, etc... Remember to give me a +1!
Step 1: Long Lasting Blade
First thing, after using a knife and it gets dirty, don't close it (if its a closing knife). The reason is because stuff like dirt, tree sap, what ever is on the blade might get stuck in the base of the knife, dulling the blade every time it is closed. This will assure your knife a long happy life. The picture is of my knife after doing my other instructable, Whittle a Staff / Walking Stick.
Step 2: Hot Water
Turn a tap on hot and wait for it to heat up. Once it is as hot as it gets, place the blade under the water for 30 seconds, rotating it.
Step 3: Electric Tooth Brush
Take an old electric tooth brush, and brush all along the blade, with some pressure. Do the same thing with both sides.
Step 4: Rinse
Rinse the blade the same way you did in step 2, to make sure it's immaculately clean.
Step 5: Dry
Dry the blade with a towel making sure that the sharp edge is facing away from the towel, not towards. Any make SURE that the blade is fully dried.
Step 6: Done.
Your blade should now be as shiny as new! Remember to give this instructable a +1!
The Instructables Book Contest
Be the First to Share
    • Photography Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Anything Goes Contest 2021
    38 Comments
    paracordry
    paracordry
    7 years ago
    Dear dirt action Julian so who would clean a knife well any one with common sense and who's mommy and daddy doesn't do everything for them ( no offence)
    thatsjet
    thatsjet
    9 years ago on Step 6
    This is kind of lame. An -ible on how to cook an egg would make more sense than this.
    owlart101
    owlart101
    9 years ago on Introduction
    I find the finger nail polish remover and a Q-tip work very well for cleaning the blade.
    scottrules
    scottrules
    10 years ago on Step 6
    Running a knife under water and using a toothbrush to scrub it? I'm seriously not trying to be negative, but I expect this kind of common sense information from ask.com, not Instructables.
    Arbitror
    Arbitror
    Reply 10 years ago on Step 6
    I made this 'ible using my method of cleaning my whittling blade, for this.
    _noth_
    _noth_
    13 years ago on Step 6
    Nice work dude. You should take some time and apply a quantity of WD-40 or similar oil on the moving parts of the knife (pivots etc.) to make sure no moisture settles in there.
    adamvan2000
    adamvan2000
    Reply 12 years ago on Introduction
    And of course, seeing as WD-40 doesn't lubricate, it only displaces water(hence the WaterDisplacement), you'd need to apply a light machine type oil.
    Polishing Peanuts
    Polishing Peanuts
    Actually, water displacement is only ONE of WD 40's properties.........Read this from their site.........
    LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.
    Sure, it is only a light lube and no where near as good as machine oil but still, WD40 will do in the field.
    fartnocker
    fartnocker
    11 years ago on Step 3
     i did this and it worked amazing on tree sap and that green stufff you get on your blade from wittling a fresh cut tree.
     before this i opened up all the tolls on my swiss and put it in the dish washer.
    Thanks!
    Patented
    Patented
    11 years ago on Introduction
    hey thanks, im sure going to try this method because I got two old knife I found in a park ! yay !
    Arbitror
    Arbitror
    Thanks for the first part! But do you think that it's ugly because of the flat blade? Believe it or not, a flat blade is far better than a rounded one! It also has a wicked little curved blade on the other side...
    Arbitror
    Arbitror
    BUCK SEKIDEN w/ 2 locking blades. It's a good little knife...
    aaaltomare
    aaaltomare
    I have this knife and it is fantastic.  I bought it new at an army/navy surplus store.  My knife has a drop point blade on one side and the other side is a 3/4 serated blade.  The thing has a wicked locking mechanism on it.  I've used this knife for a variety of projects - wood carving, bushcraft, utility projects, work, etc and it has never failed me.
    Nice tutorial on cleaning!  You can use a little dish detergent to help get those particularly nasty stains and grit off.  Also - after washing any knife you should use a little 3-in-1 for lube.
    Arbitror
    Arbitror
    Err.. I just Google imaged "Buck Sekiden", and the first image (also the only image of a Buck Sekiden knife) is the one below that I posted!
