Cleaning Rapidograph Reusable Pens
Intro: Cleaning Rapidograph Reusable Pens
Cleaning Rapidograph HELL made easy:
I have to use the super permanent ink (film) for the inking I do. So when it dries it is absolute hell to clean.
I cannot tell you how many years I spent using all sorts of garbage. I have used alcohol, 2nd degree burn worthy hot water, soap, oscillators, special Rapidograph cleaning solution, I could go on and on.
I found a random post one day a few months back mentioning using good old fashion Windex. I got off my lazy butt and decided to give it a go. I am not kidding. 10 seconds and the thing was coming off, unwinding and shaking free ink debris.
They are perfect.
- Windex
- 1/4 cup Windex solution
- Place whole nibs with ink well separated into solution
- Use Q-Tip to rub the Windex solution inside the plastic ink well. Ink comes off pretty quickly. Wash out with water
- Unscrew main black plastic housing from around the main inside nib component
- Swished a bit and within 10 seconds it breaks up quickly
- Shake the main nib component until the nib bit starts to go back and forth
- Rinse hot water and hit Windex again until satisfied
They are perfect.
25 Comments
hyperenity 1 year ago
Sherryl 1 year ago
kieshar 1 year ago
I also moved forward with watercolors as my comic medium. I "inked" specifically with watercolor afterwards. DickBlick makes it easy to see the breakdown chemically/properties of a watercolor tube color and if it has a high staining element to it. Makes it impossible to lift. I have also heard of hitting it with a setting spray like what you would do with chalk pastels as you add layers. You might play with that.
OR there is also permanent gauche. Water based until it dries. It's like acrylic but not but handles like opque watercolor ie. guache for "inking".
pfred2 10 years ago
kieshar 10 years ago
CatC 2 years ago
CatC 2 years ago
I've had a set for years that used to belong to my ex. Her being her, I assumed they were probably clogged and caked, but was delighted to find they were clean, well maintained, and quite useable. The problem came when I ran out of the cleaning solution. I live in Mexico and can order the stuff, but it takes forever to get here. But hey, there's a hardware store about 4 blocks away and they carry Windex!
I nabbed a bottle and it worked so well I tossed the Rapido-eze out of my Amazon cart! Thank you so much for this. I appreciate you taking the time to post it.
bouncepass71 3 years ago
new2thissite 4 years ago
set of Rapidograph pens for his his drawing class. They came home and
have lived in my attic since then. When I came across them, I decided to
see if I could clean them. This worked very well with Windex. When I
ran out, I tried similar glass cleaner, which was less successful. Then I
tried vinegar, and I tried ammonia, not sure which one was responsible
for the cleaning action. Neither worked as well. I went out and bought a
large refill bottle of Windex and immersed only the tips, and was
amazed at how black the solution became. I rinsed and am now on the
second soaking, and am still getting more dried ink out.
This will take a few more soakings and rinses to get all the ink out, but
then I'll have a like-new set! The only improvement I could suggest is
more details about how to dismantle the pens, as I had to look elsewhere
for that, but otherwise, SUPER!
A question to anyone more experienced with this...After soaking and rinsing the tips multiple times, I've been tapping the base (not the writing tip) of the nib, and ONE of the nibs has a slight "rattle" to it, like maybe there's a roller ball or other part inside that is now free inside. None of the rest of the nibs do that, so does that indicate that there is still more dried ink inside that has not freed up some part of the nib, or does it mean that the one that has a rattle is broken somehow?
Thanks
Ubermac 3 years ago
HowardT20 6 years ago
I have been cleaning my Staedtler-Mars 700 drawing pen set while converting it for use in my HP DraftMaster rollfeed pen plotter. Household ammonia dissolves the old ink in seconds. It's just a stronger version of Windex.
The "pen" conversion is also a snap. I bought a second set of identical pens to 'sacrifice' in this process, and it turns out that you can trim the pen barrels with a hobbby "razor saw" quite easily to the length of the ink reservoir inside, and this makes them fit the HP pen carousel. The "ring" around the pen required for it to be grabbed and held by the plotting mechanism can be added using a 7/16-in "fiber washer available at hardware stores. I used a tapered grinding stone in a 1/4" electric drill to VERY CAREFULLY enlarge the hole in the washer (Probably less than 1/32") to make a tight, friction fit around the knurled (the part with the little tiny grooves) section of the pen tip. It's easy to slide the washer onto the pen barrel using an HP plotting pen as a guide to position it, and so far, mine are tight and square enough to function perfectly. Some epoxy or super glue might be required if the washer is enlarged enough, by accident to, slip during operation. some care and patience in enlarging the hole just a tiny bit at one time allowed me to get a perfect friction fit.
LisaG208 6 years ago
OH MY!! THANK YOU!! I can’t believe how easy this was. I have tried SO many ways to clean these stupid pens. I was skeptical about the Windex, but it worked beautifully!!! I accomplished in a matter of minutes what has taken me hours to do before.
kieshar 6 years ago
Believe me, I feel your pain. So glad it helped you. Cheers!!
myakka-23 6 years ago
Thank you Kieshar, I'm going to try this.
kieshar 6 years ago
Hoped it worked for you ^^
AnnieC57 6 years ago
Thank you for the post! It works perfectly, it took a bit longer to clear everything in the nib.
kieshar 6 years ago
Fantastic!
summerlane 7 years ago
Tried for hours with no success to clean up my old pens that had sat for over 8 years and had dried up ink caked all inside the nib. Found your post and within an hour or so they're all working like brand new. Thanks so much for sharing!
kieshar 6 years ago
Hell yeah. ^___^ It was so satifiying to mine clear up after so much fustration.
therollingrook 7 years ago
I was totally skeptical, but I have to admit...THIS WORKS! Tonight I've revived about 7 rapidograph pens that I had let dry (with ink in them) in a drawer for a few years. It really is amazing!
I did use the syringe that came with the cleaning kit, but the cleaning kit's cleaning fluid is a complete JOKE in comparison to glass cleaner. (I used the cheap, generic stuff.)
Thank you so much for sharing!
