Space Saving Closet Hangers
Intro: Space Saving Closet Hangers
Increase the space in your closet by 60% for under $20!!!
STEP 1: Part List
2 packages of "S" hooks ($2.48 EACH)
PART# 62770 S Hooks C-60 6 PE
12 feet Handy Link Utility Chain ($0.52 a foot)
PART# 10165
Have a Store Assistant cut your chain to 1 foot lengths keeping 13 or 15 links in a segment.
Note:
13 links will hold 7 articles of clothing and 15 will hold 8.
PART# 10165
Note:
STEP 2: Assembly
Here's the hard part!
Hang Hook in closet,
Hang Chain on hook,
Hang Clothes Hangers on chain,
Hang Clothes on clothes hangers!
Simple!!!
Hang Chain on hook,
Simple!!!
STEP 3: Finished Product
Notes:
Any chain with a wide enough hole will work however make sure the chain and the hook is rated to hold over 35 pounds.
We used a closed/welded chain link so our cloths won't get snagged.
There is a variety of different coated chains that may brighten up your closet as well as protect your clothes.
62 Comments
mpressgrove 9 years ago
chwbcc - what a fantastic idea. My wife and I are kicking off full time RV living and obviously the space is limited. After looking at a few commercial options, this beats anything I have seen or could make; and the effort is well, effortless. I will be adding reinforcement to the closet bar to maximize the use of these. Thanks for sharing. Pictures to follow.
chwbcc 9 years ago
Awesome! These chains have been an important part of our closet now for a couple of years. This is one of those rare life hacks that is cheap, durable, and easy to make.
You will definitely need to reenforce the curtain rod if you have a lot of these in your closet. They save you space but that only means you can hang more things, and more things weigh more! LOL
Can't wait to see pics and safe journeys in the RV!
juanjok 13 years ago
chwbcc 13 years ago
wrokgoddess 13 years ago
chwbcc 13 years ago
Azze01 8 years ago
My two Cts: The idea is enticing and seems to be a good one at first sight, but... Thinking about it back and forth and inspecting my own closet, I can tell you that I never ran out of closet space because of the hangers interfering on the rail, but rather of the clothes interfering at the bottom. Fabric thickness building up is the basic problem of closet space usage, and cascading clothes down doesn't really solve it because overlapping each other they end up side by side nonetheless. All clothes on the chain sum up in thickness the same way they would right on the rail. In my eyes, only benefit you could get out of this would be with two items on one chain with the lower item on the chain ending up under the lower end of the higher item, thus doubling the usage of space by using one "slot" for two items (which should rarely be applicable for adults' clothes in most closets).
chwbcc 8 years ago
This really does save space because you can hang 6-7 articles in the space you would normally hang two.
mason0190 14 years ago
cpacker 14 years ago
Was1x 8 years ago
True enough, but I use them any way as a way to organize and control items in the closet by type and color. I found ones like the plastic hangers with holes in chromed steel with cutouts ! Cost a bit more, but held jeans on chrome or wooden hangers (which were too heavy and just pulled the plastic hooks on the rods out straight). S hooks and chain would have been cheaper & easy.
chwbcc 14 years ago
Joey John 9821 8 years ago
tonybest 8 years ago
fantastic idea
jacob alias 8 years ago
Good stuff..instead of chain , we can use cable tie in loop..even simple ..
jessicat21 9 years ago
chwbcc 9 years ago
Those old wooden rods are really strong so you probably support a lot more weight then these cheap closet racks.
I hope this helps.
Rhino12343 10 years ago
little bit smaller but works really well
chwbcc 9 years ago
Awesome!
lauramondesando 11 years ago
