Coffee Cup Splash Guard
Intro: Coffee Cup Splash Guard
It's getting cold outside. Nothing better than a hot drink on a cold morning. Nothing worse than a splash on bumpy road or a start and stop commute. Here is a reuse for yesterday's paper cup. Keep that fresh morning look, clean interior, and some perfectly good skin.
What you'll need;
Paper coffee cup
Ruler
Xacto blade or good scissors
Pencil or pen
Height adjustment tool (stack of paper or book will do)
STEP 1: Resizing Yesterday's Cup
Wash and dry yesterday's paper cup with a suitable cleanser. Place cup on flat surface with book or paper stack next to it (suggest about 2" high for a 16 ounce cup). Place a pencil or pen on the top of the stack and rotate the cup making a even height mark. Cut cup down to size using a utility blade or sharp scissors. Neatness counts but is not a deal breaker! Keep the upper section of the cup and discard the base or use it for holding misc. small items.
STEP 2: Creating Baffles in the Remaining Section of Cup
With a scissor or a utility blade make two vertical cuts about 3/4 to 1 inch wide to within 1 inch of rim of cup. Now starting from the vertical cut make diagonal cuts from base to within 1/2 inch of rim. Space cuts about 1/2 inch apart. Repeat until you have cut from around cup to other vertical cut. Fold tab made by vertical cuts parallel to rim. Fold diagonal tabs one after another creating a bowl. Next fold cup baffle in flat and place in ziplock bag until needed. To use place baffle in cup the same size as original cup.
4 Comments
KookyKreations 9 years ago
doesn't the coffee leak out of the space between the two cups when you try to drink it?
TinKicker 9 years ago
Seems like it would. I guess your lower lip would catch the drippin's. Good idea though.
BelchingDragon 9 years ago
Idimagine 9 years ago
