Connected Arm Lift, a Knex Ball Machine Lift
Intro: Connected Arm Lift, a Knex Ball Machine Lift
Hey everyone!
I present to you the second new lift from my ball machine Euphoria. The first one is here.
The Connected Arm Lift is in my opinion a cool looking lift, with a pretty low piece count.
It works very good, I've never seen a ball fall of the lift.
If you build this lift, read every image note!
I hope you like it and have much fun with building!
~Sandroknexmaster~
video:
~Sandroknexmaster~
video:
STEP 1: Piece List
First you have to count the pieces.
They're all named by their original color.
RODS:
green: 81
white: 37
blue: 50
yellow: 48
red: 88
grey: 46
Total rods: 350
CONNECTORS
dark-grey: 15
light-grey: 2
orange: 48
red: 10
green: 26
yellow: 39
white: 11
purple: 89
blue: 23
Total connectors: 263
OTHER PARTS
tan clip: 3
Y-clip: 6
blue spacer: 27
silver spacer: 76
small blue gear: 1
medium yellow gear: 1
medium hub: 1
medium tire: 1
green motor: 1
Total other parts: 117
GRAND TOTAL: 730
RODS:
green: 81
white: 37
blue: 50
yellow: 48
red: 88
grey: 46
Total rods: 350
CONNECTORS
dark-grey: 15
light-grey: 2
orange: 48
red: 10
green: 26
yellow: 39
white: 11
purple: 89
blue: 23
OTHER PARTS
tan clip: 3
Y-clip: 6
blue spacer: 27
silver spacer: 76
small blue gear: 1
medium hub: 1
medium tire: 1
green motor: 1
GRAND TOTAL: 730
STEP 2: Entrance
We will start building the entrance. Here the balls can enter the first arm.
STEP 3: Motor Section
Here we will build the motor section. It contains the motor, the gears and the axle.
Always slide the switch of the motor to the left.
STEP 4: Frame
This is the most boring part from the lift... But it's also very necessary so just build it!
STEP 5: Exit
The exit. Here leave the balls the last arm.
STEP 6: Arms
Now we will build the four arms. They pass the ball to eachother so it can get from the entrance to the exit.
STEP 7: Arm Connections
This is the last part from the lift. They connect the arms and the cranks.
STEP 8: Finished!
Yay! The Connected Arm Lift is complete!
Thanks for building my lift or watching the ible only.
When you've built the lift send me a photo, then I can add it to this step!
I hope you liked it!
See you!
~Sandroknexmaster~
87 Comments
engineer711 3 years ago
ses6761 8 years ago
We just built this lift. It works great for a couple of rotations, then there seems to be a problem with the gears meshing. It starts skipping and binding. Any ideas?
sandroknexmaster 8 years ago
Did you use the same motor as in the instructions? If not, yours might be not strong enough.
ses6761 8 years ago
Yes, the green one.
That's weird, then I suggest you try to place the gears in a different position. Maybe then it will work.
autumsawesome 8 years ago
here is mine you can see a instructable with it at
https://www.instructables.com/id/Blizard-10-a-Knex-ball-machine-in-progress/
That_Jamie_S_Guy 8 years ago
Thanks for building!
TheUnfortunateHobbit 9 years ago
sandroknexmaster 9 years ago
Hm that's very weird, I've never had trouble with this lift, it always worked great. You can send pics, questions, or any other things I can help you with in PM. I'll do my best to help you out.
btw, 2600th comment :D
Sorunome 10 years ago
sandroknexmaster 10 years ago
hunter999 10 years ago
cooljupjup 11 years ago
sandroknexmaster 11 years ago
