Contemporary Railings Using Skateboard Wheels
Intro: Contemporary Railings Using Skateboard Wheels
My first instructable!!!
After getting really expensive quotes for my railings, i decided to make my own. i got inspired by my skateboard wheels, i liked how the light shined through. i purchased some stock steel channels to use as posts, machined the wheels to hold the glass panes and then took measurements about 17 different times and ordered the glass. everything fit perfectly and i saved 6000$.
You might not need railings, but maybe this will give you other ideas!
STEP 1: Posts
i used 3 inch channels to make the posts. check with your local building codes, but here railings have to be 42 inch high. i made the posts 40 inch as the glass pane goes 2 inches higher than the posts. make sure you're installing them in something solid!
STEP 2: Tests, Plans and Machining.
i decided to do a little test as i wasnt sure how urethane wheels would react on the lathe. turned out its like butter, you just need to crank up the speed as fast as possible otherwise the cut isnt clean. once i knew it would work, i ordered 10 sets of wheels from a wholesale place.
i decided to use 6mm thick tempered glass. call the glass shop and ask what size holes they can make before you start... i got lucky... i machined the wheels at 38mm, and they could do 40mm holes in the glass. the 2 mm difference made everything fit much better!
i made a tool to hold the wheel in the lathe from its center, then the first step was to make one side flat. that side will be the back. i did all 38 wheels, then moved on to the next step. i grooved the front part of the wheel where the washer will sit. i then cut the wheel removing the entire front part, and then machined it so that the center diameter is 38mm and 6mm wide.
it took me about 8 hours to make all 38 wheels, and at least 1 to clean the entire shop... urethane dust is sorta sticky... oh yeah, wear a mask when you machine it!
STEP 3: Hardware and Math
i decided to use industrial hardware mostly because of looks, i like the big hex bolts. here's the assembly line. the washer is actually smaller than the hole in the glass, meaning even if you overtighten the bolt it wont put more pressure on the glass. the bolt i use is just the size of the inner part of the wheel so there's no play.
i didnt actually take the hardness of the wheel into account, i just know they can take a beating. rule of thumb is that the thickness of the glass in mm divided by 2 equals the weight of the glass in lbs per square foot. so, 6mm means 3lbs per square foot. lets say the pane measure 4ft by 6ft, that means 24 sq/ft, times 3 = 72lbs. then divide that by 4 (since there's 4 wheels per pane) that means 18lbs per wheel... i know for a fact they could handle a lot more. the widest piece of glass i'm using is about 7ft wide, so instead of adding a post in the middle to prevent the glass from flexing too much, i just put the 2 posts farther from the edges than the other. another thing worth noting is that holes in the glass panes need to be at least 4 inches from the edges.
STEP 4: Post Holes
i didnt take pictures of this but using a magnetic laser level i made marks on every post to know exactly where to make the holes for the bolts. then uninstalled the post, labeled them and went in the garage to make the holes using the press drill.
in a stroke of genius i decided to make little holes each sides of the big bolt hole, so that sunlight would shine through to the wheel (it works - looks like if there's 2 little LED in the wheel...). once the holes are done, i re-installed the posts, put the wheels on and took measurements for the glass. take extra time doing this because it needs to be perfect.
STEP 5: All Done!
when i received the glass, it actually took me more time to open the crates than to install the glass. it fitted perfectly the first time.
here's pics of the end results!
26 Comments
Smarti1957 9 years ago
For $1000's worth of materials, that's a pretty fancy schmancy railing you ended up with. You can't put a price on uniqueness and creativity. Well done.
colelemi 11 years ago
barrym 11 years ago
mart! 11 years ago
the rest was just labor time. took one day to do the wheels, and about 2 or 3 days of measuring everything 17 times. once everything was in place, the glass took longer to uncrate than to install.
barrym 11 years ago
EnergyHandyman 11 years ago
Or a wheel mfg.
But I know making it yourself felt good. Very awesome engineering.
mart! 11 years ago
you dont learn much by paying someone else to do something for you. if everybody did that, we wouldnt have this website!!!
that said, the 40 wheels cost me a tad under 100$ shipped to my door. i tried contacting a wheel co. but they never replied, i doubt they would have given me a better price, a set of 4 from a known brand is usually about 38$. And i'm pretty sure 3d printing would have cost a lot more...
i wanted skateboard wheels because they actually mean something to me, more than any other generic manufactured part...
stuie25 11 years ago
mart! 11 years ago
clazman 11 years ago
I think that the lock washers may be unnecessary. Are they actually being compressed? there shouldn't be any tendency for the nuts to loosen, no building vibrations, i.e. heavy nearby traffic ; ). "Locktite" on the threads?
But three cheers to a nicely thought out and artistic design!!! ; )
mart! 11 years ago
they're not lock washers, just regular washers used to spread the weight wider on the wheel face. any vibrations are suppressed by the urethane wheel.
the house is very minimalistic, very precise and almost chirurgical. i used wood, iron and concrete to counterbalance it all. the goal was to use these materials in the most original form possible, including their flaws; some iron posts have yellow pen markings on them, some are slightly stained or rusted. i used cedar to cover a wall in the kitchen, its full of knots and imperfections, its not coated with anything so it will change color with time. the concrete floors have marks, cracks and stains that change with time... its not some kind of ideology or dogma, its just some design guidelines i set myself when i started to design the house. just a path layed out so that it doesnt end up looking all over the place!
AND, it also kept costs down a lot!
Oscelot 11 years ago
stevet47 11 years ago
Microbe 11 years ago
fmhiggins 11 years ago
Matt Carl 11 years ago
laferte 11 years ago
megaduty 11 years ago
mart! 11 years ago
cheers!
