Converse Roller Blades
Intro: Converse Roller Blades
I had a pair of roller blades lying around which I never wore because they were not very attractive, so I decided to make them cool.
If you want to do the same, you will need:
- An old pair of roller blades
- White Acrylic paint
- Painters tape/ masking tape
- Silver & Black sharpies
STEP 1: Step 1: Base Color
My roller blades happen to be all green, so to prep them, I cleaned, dried, and lightly sanded them. If yours are not solidly colored, you may want to paint them after prepping. (I used Acrylic paint and Sharpies for all of my detailing.)
STEP 2: Step 2: Tape Off the White Detailing
Everyone knows the white tip and trim are the signature for the Converse sneaker look, so this is a very important step! The more care you take to make your tape lie straight and in the pattern of the sneaker, the better your results will be. I used blue painter's tape, then thinner patterned tape (with equivalent sticky-ness, and water proof-ness) to make the lines more exact.
STEP 3: Paint!
I used Acrylic paint in my project and found that it has held up well (after 4 outdoor test drives). That being said, I GLOBBBED it on. And if you take this approach, I warn you that it takes a very long time to dry. Never the less, I recommend that you work in sections (I did the front, then the sides) and be patient!
STEP 4: Step 4: Put in the Details
Once the paint is completely dry, peel off the tape.
Your skates should already look pretty kickin' but the more details you put on, the cooler they are going to look. I jazzed mined up with:
- Converse style logo: White acrylic painted circle, drawn on with green, black, and silver sharpies
- Stitching: Drawn on with black sharpie
- Hardware: Two small circles drawn with silver sharpie
12 Comments
Kiteman 11 years ago
eitaknella18 8 years ago
So did I!!
BarginsTech 11 years ago
alliehernandez 11 years ago
chuckyd 11 years ago
Jayefuu 11 years ago
aarghdanii 11 years ago
ah memories:)
destructopop 11 years ago
ilpug 11 years ago
cerqueic 11 years ago
