Cooking... With Your Car
Intro: Cooking... With Your Car
Reusing some waste heat in from your engine bay to cook a meal on your way home.
After I showed this to a few people, I found out that there is a book called "Manifold Destiny" on this very subject. I have not read it yet, but I'm told that there are quite a few recipe's with locations and times (miles).
STEP 1: Gather Some Ingredients
This was mostly improvised... But on my menu:
+Baked Chicken and Herbs (chicken breast, flour, your choice of herbs - I used mostly basil)
+Italian Chicken (chicken breast marinated in zesty Italian salad dressing cooked with pepper and onion)
+Red and Green Peppers and mushroom Noodles (used noodles from a ramen package, added a little EVOO, and cooked in vegetable stock)
+Baked Potato Pieces (salted with a little cooking oil)
+Baked Apples (sliced in half with a pat of butter and scoop of brown sugar)
STEP 2: Prepare
Layout each item on foil sheets large enough to wrap.
The chicken breasts will be cooked in rectangular like packets to expose as much surface as possible. We want a cup like shape for the noodles/veggies.
STEP 3: Sealing
Everything should be wrapped in a few layers of foil. Not so much to protect the food from anything, but really to protect the car from spillage.
The noodles require a little extra care. As we're adding fluid (veggie stock), we need to make out 'cup' with a sealable opening. However you feel is best is the way to go here ;)
On the note of toxic gasses (I'm asked this all the time)
If your car is emitting gasses (say exhaust or coolant steam) from under the hood, you have a problem and you should probably have that looked at. A maintained car does not do this which is why I'm not concerned with doing this.
STEP 4: Placement
Placing your food is very important... As every car and engine configuration is different, you'll need to use some common sense...
Potato and Chicken will require the most heat so they should be placed on or near the exhaust manifold. Apples should be placed near something hot (I put it on the top radiator hose). The noodles can be placed on top of the valve cover (if possible) as they can take lower heat for longer times and still cook properly.
STEP 5: Cook Time
I was driving 200 miles, so I had to plan accordingly. I drove 100 miles (speed was around 70-80mph) and nearly overcooked the chicken. But at that rest stop I had 1 chicken breast and it was delicious. When I came to a stop, the smell of the chicken and herbs surrounded the car. And at the horror of onlookers, I proceeded to eat from my engine bay.
After the 100 miles, the chicken was well browned -- I think 60 miles would have done the trick.
At this time, the noodles were done, and were moved to a slightly cooler area. The potato package was still raw as I had placed it in an area too cool to cook properly.
STEP 6: Other Suggestions
Shrimp is VERY easy to cook and gives of a wonderful aroma. Only 20-30 miles on surface roads is needed -- but modify for extended periods stuck in traffic.
On my next long trip, I'd live to make a rack to support a pork roast or even a rack of ribs to cook slowly.
This type of cooking requires some practice and experimentation. But what's better than pulling up to a gas station and pulling out some chicken wings from under the hood while you fuel up?
Drinks! The striker plate (the part that holds the door closed) on most cars is a great glass bottle opener should you find yourself in the middle of nowhere with a coke and no bottle opener ;) Just look inside the door frame for something that resembles a bottle opener.
BTW, this is a '97 Mazda 626 -- equipped with bottle opener and oscillating vents (for some goofy reason) :P
109 Comments
SeaSkyShore 14 years ago
BleepinJeep25 8 years ago
what part of idaho? im from CDA
Kasm279 13 years ago
anode505 8 years ago
....combine ingredients and cook at 60mph for 40-70 miles. :)
I've been menaing to try this. I do road trips every so often.
muscadeep 8 years ago
terrific :)
digdug18 10 years ago
GabbieZee 11 years ago
Fend1952 11 years ago
jvell 12 years ago
spark master 13 years ago
trebuchet03 13 years ago
Phil B 12 years ago
Once I was to meet my wife so we could go someplace and she had not eaten. I wrapped a frankfurter in aluminum foil and rested it on the exhaust manifold for the 30 minute drive. It was nicely cooked when she ate it.
Back in the mid-1960s I saw an article in the Minneapolis Star about a family that cooked roasts and potatoes on their engine when taking family vacations. It was the days before the Interstate highway system was widely in use and roadside rest parks were easy to find. They drove for a period of time, stopped, and turned their food so it could cook on the other side. When the food was done, they stopped at a rest park and ate it while seated at a picnic table.
My daughter was interested in this and I checked into the book "Manifold Destiny." It is out of print and available copies were quite expensive. I expect a person could do what you are doing--experiment and make notes.
I thought it would be interesting to make a basket or enclosed box that would absorb heat from the engine, but would also protect it from air drafts and from falling down to the road, as well as from tearing or opening of the foil so the food was contaminated by dirt or oil.
klincecum 12 years ago
Phil B 12 years ago
spark master 12 years ago
If you have a way to rig the outer pot safely even permanently you could add a few rows of foil ribbing. You use the tape used on exhaust ducks off boilers (stainless or aluminum metal tape). people use that technique to make collars for "heiny can" pots and thus get better boil times for Alcohol stoves (see you tube vids as well as )If you go to a camping store look at "Jet Boil" items. Google Bill Wrigley and alcohol stoves, and see his stuff, he came up with the foil tape idea.You could just take heat sinks from old computer equipment and rivet them on the outer can.
My car is now too new to screw with it, so I will not be mangling the guts of the engine compartment! But if I see a place for it.....hot dogs fer lunch with kraut and homemade NYC dog onions, mmmmmmm.. bettr then Hojo any day..
ttfn
dasgemuse 12 years ago
kadalmesir 12 years ago
