Cotton Wool Ball and Petroleum Jelly Firestarters
Intro: Cotton Wool Ball and Petroleum Jelly Firestarters
I've seen different ways to make firestarters from cotton wool and Vaseline (petroleum jelly). This is the quickest way I've found and makes excellent firestarters that keep for ages and burn for about 6-7 minutes.
You’ll need:
- Cotton wool or cotton wool balls
- Vaseline (petroleum jelly)
- Saucepan
- Paper towel
- Tongs
- Paddle pop stick
You’ll need:
- Saucepan
- Paper towel
- Tongs
- Paddle pop stick
STEP 1: Melt Some Petroleum Jelly
Roll up some cotton wool into balls about an inch wide. They don't need to be any bigger as they produce a good flame at this size.
Melt some petroleum jelly in a saucepan over a low heat until it’s liquid. A tablespoon of PJ will make about six firestarters.
STEP 2: Dunk Each Cotton Ball
As soon as the PJ is completely melted, take it off the heat and dunk each cotton ball in the liquid PJ unti thoroughy saturated.
STEP 3: Squeeze Out the Excess
Give it a good squeeze until no more PJ drips out, then set it aside on a piece of paper towel to drain.
STEP 4: Set Aside to Dry
Let them dry for a couple of hours, then store in an airtight container.
18 Comments
RoBear613 7 years ago
Have you tried dryer lint? I remember the scout handbook had a fire starter that used lint and paraffin. Figure the PJ can be used.
MrJamesIkanov. 7 years ago
You may get increased performance by adding in paraffin wax.
LoboR1 9 years ago
I've done this before. It does not work very well.
The reason is because the petroleum jelly does not ignite as easily as the cotton does. If you soak the cotton completely in the jelly, your spark/flame has to heat the jelly to its liquid phase before it can ignite the fumes coming off of the liquid.
The dry cotton ball will ignite much more easily. Rather than saturating the cotton ball through, smear the outside of it with the petroleum jelly. Leave the inside of it dry cotton. Having the outside smeared will keep the inside protected from moisture. When you are ready to ignite it, tear the cotton ball open, so the dry cotton can catch your sparks. The cotton will ignite, and that flame will then ignite the petroleum jelly. It will work like a candle at that point, with the cotton serving as a wick to the jelly.
One way easy and less messy way to do this is to put the cotton balls and glob of petroleum jelly into a ziplock baggie, and knead them until the outsides of the balls are thoroughly coated.
PatrickH12 8 years ago
Thanks for the info.
walksalone 8 years ago
This is exactly the process I use and it has served me well for many years. I started using direct low heat with no mishap and no trouble cleaning up using that new stuff...I think they call it soap.
I use an old double boiler now just for convenience.
jazzguitar1963 9 years ago
Unfortunately, you are completely wrong. I've been using these for years and as recently as last weekend, used a batch that were over two years old. They ALWAYS light and burn perfectly, and there is certainly no issue with them igniting easily at all. I've tried the way you suggested and it is far messier.
Lorddrake 12 years ago
I was thinking of just taking a small glob and working it into the cotton ball with your fingers .. but your method seems alot easier and will provide a more even saturation of the cotton.
Thanks.
reallyreally 11 years ago
strmrnnr 11 years ago
I think that may work also.
louis496 12 years ago
To be clear, melting petroleum jelly, paraffin wax, or other similar materials is very dangerous as they are fuels. When melting anything like these materials you should be using a double boiler. This will help control the amount of heat transfer to the material being melting, and can prevent some serious flash fires. If lower melting temperatures are needed, by partially submersing the second pot in the water and keeping the water at the desired temperature bellow 100 °C, they can be achieved safely.
Know the properties of the materials you are melting! The melting point of petroleum jelly is approximately 37 °C
jazzguitar1963 12 years ago
aristide202 11 years ago
hjjusa 12 years ago
chokapi 12 years ago
Also, if you can find some, white birch bark (WBB) burns like a big flat match. Put one of these firestarters on two square inches of WBB, you've got a good minute to get a fire going.
Only gather downed WBB. You don't want to hurt one of these beauties by pulling bark off the tree. You can often find pretty large pieces as they slough bark in sheets. Cut 'em up and add them to your firestarter kit.
hjjusa 12 years ago
Reffner 12 years ago
-first aid without having to carry a separate tube
-due to it being petroleum based it lights and burns as well as petroleum jelly
There would be no need for wax, because if the cotton ball is saturated well enough,.it's already water proof. Great idea melting it, but I suggest NOT doing it with an open flame.
knexfreak32 12 years ago
