DHT11 With Raspberry Pi Pico
Intro: DHT11 With Raspberry Pi Pico
The DHT11 is a commonly used temperature and humidity sensor. The sensor comes with a dedicated NTC to measure temperature and an 8-bit microcontroller to output the values of temperature and humidity as serial data. The sensor is also factory calibrated and hence easy to interface with other microcontrollers. The sensor can measure temperature from 0°C to 50°C and humidity from 20% to 90% with an accuracy of ±1°C and ±1%.
STEP 1: Step 1 : Connect Pins of DHT11 With the Pins of Raspberry Pi Pico
DHT11 pin > Pi Pin
Vcc > Pin 36
GND > Pin 38
Data > Pin4(GPIO28)
STEP 2: Step 2 :Write the Code Save It As Dht11.py and Run It
import array import micropython import utime from machine import Pin from micropython import const class InvalidChecksum(Exception): pass class InvalidPulseCount(Exception): pass MAX_UNCHANGED = const(100) MIN_INTERVAL_US = const(200000) HIGH_LEVEL = const(50) EXPECTED_PULSES = const(84) class DHT11: _temperature: float _humidity: float def __init__(self, pin): self._pin = pin self._last_measure = utime.ticks_us() self._temperature = -1 self._humidity = -1 def measure(self): current_ticks = utime.ticks_us() if utime.ticks_diff(current_ticks, self._last_measure) < MIN_INTERVAL_US and ( self._temperature > -1 or self._humidity > -1 ): # Less than a second since last read, which is too soon according # to the datasheet return self._send_init_signal() pulses = self._capture_pulses() buffer = self._convert_pulses_to_buffer(pulses) self._verify_checksum(buffer) self._humidity = buffer[0] + buffer[1] / 10 self._temperature = buffer[2] + buffer[3] / 10 self._last_measure = utime.ticks_us() @property def humidity(self): self.measure() return self._humidity @property def temperature(self): self.measure() return self._temperature def _send_init_signal(self): self._pin.init(Pin.OUT, Pin.PULL_DOWN) self._pin.value(1) utime.sleep_ms(50) self._pin.value(0) utime.sleep_ms(18) @micropython.native def _capture_pulses(self): pin = self._pin pin.init(Pin.IN, Pin.PULL_UP) val = 1 idx = 0 transitions = bytearray(EXPECTED_PULSES) unchanged = 0 timestamp = utime.ticks_us() while unchanged < MAX_UNCHANGED: if val != pin.value(): if idx >= EXPECTED_PULSES: raise InvalidPulseCount( "Got more than {} pulses".format(EXPECTED_PULSES) ) now = utime.ticks_us() transitions[idx] = now - timestamp timestamp = now idx += 1 val = 1 - val unchanged = 0 else: unchanged += 1 pin.init(Pin.OUT, Pin.PULL_DOWN) if idx != EXPECTED_PULSES: raise InvalidPulseCount( "Expected {} but got {} pulses".format(EXPECTED_PULSES, idx) ) return transitions[4:] def _convert_pulses_to_buffer(self, pulses): """Convert a list of 80 pulses into a 5 byte buffer The resulting 5 bytes in the buffer will be: 0: Integral relative humidity data 1: Decimal relative humidity data 2: Integral temperature data 3: Decimal temperature data 4: Checksum """ # Convert the pulses to 40 bits binary = 0 for idx in range(0, len(pulses), 2): binary = binary << 1 | int(pulses[idx] > HIGH_LEVEL) # Split into 5 bytes buffer = array.array("B") for shift in range(4, -1, -1): buffer.append(binary >> shift * 8 & 0xFF) return buffer def _verify_checksum(self, buffer): # Calculate checksum checksum = 0 for buf in buffer[0:4]: checksum += buf if checksum & 0xFF != buffer[4]: raise InvalidChecksum()
STEP 3: Step 3: Then Write This Code and Save It As Main.py and Run It
from machine import Pin, I2C import utime as time from dht import DHT11, InvalidChecksum while True: time.sleep(5) pin = Pin(28, Pin.OUT, Pin.PULL_DOWN) sensor = DHT11(pin) t = (sensor.temperature) h = (sensor.humidity) print("Temperature: {}".format(sensor.temperature)) print("Humidity: {}".format(sensor.humidity))
9 Comments
krzysztof198 5 months ago
Temperature: 0.0
Humidity: 0.0
or
Temperature: 23.0
Humidity: 59.8
Do you know how to fix this?
mk1botshc 9 months ago
Traceback (most recent call last):
File "<stdin>", line 9, in <module>
File "dht.py", line 53, in temperature
File "dht.py", line 38, in measure
InvalidPulseCount: Expected 84 but got 0 pulses
jballinger2 12 months ago
1. I saved the Dht11.py file as dhtlib.py
2. In my main.py I changed
to
from dhtlib import DHT11, InvalidChecksum
Code works perfect! When I tried using the inbuilt library (dht from micropython) I was getting values like 650ºc which is not right. I know get 25ºc and 65% humidity.
Cheers.
JimC135 1 year ago
정훈이1 1 year ago
robotobor 1 year ago
LutfullahK 1 year ago
JackR13 2 years ago
wobblykiwi 2 years ago
