DIWire Bender
Intro: DIWire Bender
D.I.Wire Bender is a rapid prototype machine that bends metal wire to produce 2D and 3D shapes, pushing the limits of what can be produced in different materials, forms, and methods, anywhere from a model shop to your home.
For the code, full bill of materials (parts list), and readme files, visit the project page on our Google Code site.
The files can be found under Download. The code can be found under Source/Browse.
*****UPDATE - SEPTEMBER 2015*****
It's been a great couple of years since we posted this first DIWire prototype! A lot has happened in those two years, and we have moved on towards the future of the DIWire. We encourage everyone who wants to take on making their own bender, but you should be aware that the original instructions were made with older versions of Processing, including those older libraries. We haven't updated the Instructable, and can't offer support for it, but with some independent R&D you can dive in on your own.
Feel free to check out our current machine for sale over at our website.
Tools
3D printer , Rapid Prototyper
General hand tools
General power tools
STEP 1: Wiring and Motors
2. Connect motors to the drivers - this wiring depends on the motors and drivers you select. If you use the ones we did, its a quick connect with a Molex connector.
3. Connect drivers to the Arduino. Most motor drivers have a direction, pulse and common ground wires or CW pulse, CCW pulse and ground. These are the ones you are mostly concerned about. Some have "all windings off" and other options.
4. Connect one of the solenoid of the leads to the power supply.
5. Connect the relay DC control to the Arduino pin and the common ground. If it's a solid state relay, be sure to connect it in the right direction, or it won't switch. Connect the Normally Open (NO) lead to the power supply and the other side to the solenoid.
6. Put the steel gear on the bender motor, and the knurled knob on the feeder motor. Don't put the nylon gear on the Z-bend motor yet.
7. Before the next step, test the Arduino and Processing programs to make sure the gears turn and the solenoid moves as expected.
STEP 2: Drilling Holes
2. These dimensions are not very critical, but there are a couple of things to keep in mind if you want to do it without referencing the file:
-The straightner wheels should just touch.
-The center line of the wire should follow a straight path from the straightener to the guide, to the tangent of the knurled knob, to the tube.
STEP 3: Attaching Motors
2. Put in Z-Motor. (Make sure to keep the screws loose until the end to make it easier when attaching the gear.)
3. Attach nylon gear to Z-Motor.
4. Attach feeder motor to top base.
5. Tighten everything down.
STEP 4: Support Beams
STEP 5: Attaching Motors
2. Attach top base to bottom base. We used 80/20 10mm profiles, but anything would do — a piece of ply would be good. The height is not critical, just enough to clear the motors.
3. Attach switch to battery and top board.
STEP 6: Attaching the Bend Tube
2. On one end of the tube attach the other nylon gear. This will interface with the Z-motor. Note: Our gears did not come with hubs, so we made our own, but it's a lot easier to use a gear with a hub if you can find one.
3. Bolt our 3D-printed motor plate to the shaft mounts.
4. Loosely attach the metal shaft mounts to the other end of the tube.
5. Attach the tube assembly to the top plate. We used a couple of washers to space the gears apart so they turn smoothly.
6. Install bend motor to the 3D-printed motor mount.
STEP 7: Building the Solenoid
2. Attach gear to base.
3. Put solenoid into base.
4. Slide the brass bushing into the base. This allows the solenoid pin to slide smoothly, and spreads the load so the base doesn't crack.
STEP 8: Attach the Solenoid
2. Attach the solenoid assembly with the shoulder bolt.
STEP 9: Solenoid Pin
2. Drop solenoid pin into hole.
3. Drop the extension pin into hole and stick a cross-pin through the hole to keep it together.
STEP 10: Lever Arm
2. Attach the lever arm to the top base.
3. Attach an angle bracket with a bolt so the bolt applies pressure to the end of the lever arm.
STEP 11: Installing Straightening Wheels
2. Attach wheels to top board. You can use a staggered pattern instead of the linear pattern in the photos. You can also have straightener wheels on multiple planes so you straighten the wire from multiple directions.
STEP 12: Feed the Wire
2. Attach spool to wire feeder at the end of the board.
Voilà! You're done! Tell us how it turns out — diwire@pensanyc.com — and we'll post it on http://blog.pensanyc.com. Enjoy!
27 Comments
ErwinM5 3 months ago
EdsonO5 3 years ago
Brilhante estratégia de marketing: lancemos um produto de grande aceitação de baixo custo e gratuito e brevemente atualizemos por modelos “comerciavelmente viáveis “
Também construí seguindo corretamente as instruções e simplesmente não funcionou .
Entrei em contato e disseram a mesma coisa: o Di Wire 1.0 morreu, mas se quiser temos outros modelos.......
hawth725 4 years ago
pensa 4 years ago
ÖmerS37 5 years ago
antoniovigil963 5 years ago
where can i get the roller that pulls the wire ?
pensa 5 years ago
use a knurled knob, that works pretty well for prototyping.
pensa 5 years ago
we used a stepper to pull the wire
it is possible to replace the 300 μF ceramic capacitor with an electrolytic one?
pensa 5 years ago
yes, I believe so.
MakeMore 7 years ago
What version of Processing was used in this project?
rmedeiros1 10 years ago
Hello,
The design is sensational, it was a great idea. and you are so kind to share this project.
I'm riding one for my use and study, but I have a doubt.
Can you help me?
Products:
2 Phase Stepper Motor - Oriental PK264A2A-SG10
Stepper Motor Driver - Eastern CMD2120P
These two items are very expensive and flees my budget.
They can be replaced by others with lesser value?
Type Nema the manufacturer.
If the exchange is possible on the other, what is the model?
antioch 11 years ago
What program lets you add that beautiful label effect in the fly-by sequence starting at 05:01 ?
cwatts4 11 years ago
sadiablo 11 years ago
http://blog.pensanyc.com/post/22264370500/the-diwire-bender-how-to-bend
Alienjones 11 years ago
Great job. Thanks for showing us that invention beats imitation any time! Got any other great projects to share?
Edgar 11 years ago
Good idea, and instructable, went to my Blog:
http://faz-voce-mesmo.blogspot.pt/2013/01/modi-bots-algo-de-importante-e-um.html
Wazzupdoc 11 years ago
shannonlove 11 years ago
florin2901 11 years ago
