DIY 1000 Watt Wind Turbine
Intro: DIY 1000 Watt Wind Turbine
We built a 1000 watt wind turbine to help charge the battery bank that powers our offgrid home. It's a permanent magnet alternator, generating 3 phase ac, rectified to dc, and fed to a charge controller. The magnets spin with the wind, the coils are fixed, so no brushes or slip rings necessary.
Update: DIY Amp Hour meter for monitoring charge!
All about homebrew wind and offgrid power systems, the complete reference!
STEP 1: Build the Magnet Disks
We had 12" steel disks hydro cut. We cut a template for mounting the magnets. Then we mounted 12 grade n50 magnets around the outside edge. We then built a form, and poured the resin with hardner.
STEP 2: Build the Coil Disk
We wound the nine individual coils, soldered them in a 3 phase wye configuration, and encased them in resin. We used 35 turns of 2 parallel strands of 14 gauge enameled (magnet) wire for 12 volts. Use 70 turns of single strand for 24 volts. # 3 phase diagram shown here shows 3 stator coils. each of those coils is actually 3 coils in series. coils 1,4, and 7 are series together, 2,5, and 8 are series together, and 3,6, and 9 are series together.
more details, see the following page 15 for the series star, 1-y diagram.
http://groups.yahoo.com/neo/groups/axialflux/files
AXIAL_FLUX_HowItWorks.pdf
STEP 3: Build the Bearing Assembly
Two Harley Davidson wheel bearings are inserted into the pipe, with a smaller pipe locked between them to keep them in place.
STEP 4: Construct the Blades
The blades are 2" x 6" pine, cut at 10 degrees on a table saw, and sanded into a rough airfoil. Not perfect, but close enough.
More can be found at
http://tech.groups.yahoo.com/group/axialflux/
http://www.green-trust.org
http://youtube.com/watch?v=o9EEHFKEckM
1896 Comments
AlexK212 6 years ago
Hello greetings
How do you control the battery charge
What device do you use to control the load
I would like to know the characteristics of the device for the charge control of 1000 watts
thanks for your attention
sspence 6 years ago
AlexK212 4 years ago
83/3 = 27 amperios por fase.
es correcto
lo que quiero preguntar que amperaje de cada bobina de 12 voltios
tcmarlar 4 years ago
anthonypape37 2 years ago
pwaterberg 3 years ago
An oscilloscope will tell you more. It will also tell you that because of the thick stator wires the voltage is very low.
BrentM76 4 years ago
sspence 4 years ago
sspence 4 years ago
assasinsareus 4 years ago
sspence 4 years ago
Khalid0001 2 years ago
Thanks
michael.pittner 3 years ago
tricooltransformers 5 years ago
Less current means less losses , and cheaper wiring. If we look at 100 W , the current at a voltage of 200V is 0,5 A , and can be handled by a 0,5 mm copper wire . The same 100W at 12V is 8,5 A , and requires a 1,9 mm copper wire. If the losses in your circuit are for example 0.5 Ohm , you lose 0,25 V in case if the 200V , and 4,25 V in case of the 12V. Nowadays convertors are very efficient to bring down high voltages. Modern power cables in the offshore industry can be up to150.000 V , and DC , for the same reasons. In the near future I will investigate thin wire stator coils wound around a laminated metal core , and connected in series , producing a high voltage pulsating DC. This also because of the fact that I think to have found a solution for the "clogging " ,or friction , involved. Cheers from the Netherlands.
Edelma 4 years ago
Joe Daniels 4 years ago
dozerpanaan 3 years ago
Did you ever test the turbine in Watt load current mate?
