DIY Adjustable Router Template
Intro: DIY Adjustable Router Template
I made this adjustable router template based on Festool's MFS Multi-Routing Template http://amzn.to/1QaqWtM.
Building this thing out of plywood keeps the cost down SIGNIFICANTLY compared to the commercial aluminum model, but fulfills the same features and works with the same clamps!
Specifically, these clamps:
- The ratchet-style http://amzn.to/1Qarfos
- The screw-style http://amzn.to/1Qarn7j
- (technically, you don't even need these special clamps as long as you don't mind a clamp directly on the surface)
This system offers the most versatile template routing setup that I am aware of, and it can be had with just a couple hours in the shop + a few bucks worth of plywood.
Stuff you'll need to build this:
- Some 3/4" plywood
- 4 of #10-32 x 3/4" machine screws
- 4 of #10-32 hex nuts
- A router (preferable in a router table)
- 1/2" keyhole router bit http://amzn.to/1Qassfp
- 3/8" keyhole router bit http://amzn.to/1o27rGW
- Pocket hole jig http://amzn.to/1QasqEu
STEP 1: How It Works
T-tracks on the edges of each profile provide the size adjustment, and pocket holes (with machine screws) lock in any specific size.
The hardware used is:
- #10-32 x 3/4" machine screws
- #10-32 hex nuts
For a detailed look at the profiles, check out the SketchUp model in the next step!
STEP 2: SketchUp Model
Here's a dimensioned view of the profile.
You can download this SketchUp model from my website: http://fasteasysmarttool.com/template/
STEP 3: Cut the Plywood
Now to build it! Ripping an 80mm wide board off a sheet of 3/4" plywood.
STEP 4: Sand the Plywood
I take this opportunity to smooth the plywood. Best to do this now, as the surface becomes too intricate after all the T-tracks are cut in.
STEP 5: Route T-tracks on the Faces
Using the 1/2" keyhole bit (http://amzn.to/1Qassfp), I make T-tracks for the clamps.
STEP 6: Test Fit the T-Tracks
The clamp should fit in the slot and slide freely (when not engaged, of course).
STEP 7: Route T-Tracks on the Edges
Pockets holes are on a 15° angle, so I set up a 15° fence on the router table for this step.
Now I'm using the 3/8" keyhole bit (http://amzn.to/1o27rGW).
STEP 8: Drill Pocket Holes
It may take some trial and error to get the position of the pocket holes just right so it fits in the T-tracks. Just be patient.
Pocket hole jig: http://amzn.to/1QasqEu
STEP 9: Cut to Length
Make as many of these as you want, and cut them to any length.
STEP 10: Assembled and Complete
You're awesome!
Thanks for reading :)
30 Comments
JGDean 8 years ago
While I love many of the Festool ideas, their prices put them totally out of reach for me. Just the screw-type clamps that you show are $43 each, while Bessey makes essentially the same thing for $22, also available on Amazon. I may have champagne tastes, but I have a beer budget. Sorry, Festool.
Toolify 8 years ago
That's funny because the screw clamps are $43 for a 2 pack :P $21.50 per clamp, therefore $0.50 cheaper than the Bessey
JGDean 8 years ago
Sorry, I missed that part and was going by where it said "Item Package Quantity: 1" . Makita also makes similar clamps ($38.73/pair).
However, I'm enough of a metal-worker to make my own anyway and have made something similar (mine were smaller and lighter-duty). I would have to modify my design to work in a track. The one shown cost less than a dollar.
aodennison 4 years ago
The Bessey TK-6 Table Clamp $8/pr are cheaper but have a 1/4" round bar which is similar to your homemade, but may not fit some T-Track. BTW T-Trak dimensions vary. See https://www.woodtalkonline.com/topic/15480-are-all-t-tracks-the-same/
I like your homemade clamps even better. Looks like a square U-Bolt cut in half. National Hardware N222-364 2192 Square U Bolts in Zinc, #535-5/16"x2"x5" about $3 makes 2.
Toilet Flange bolts also called "T-bolts" or Closet bolts are often cited for jig hold downs for use with T-Track. They slide a little bit better than hex heads, since the heads are rectangular. These can be found for $1 / pair.
misterxp 6 years ago
Just what I needed. Thanks!
Toolify 6 years ago
Jayefuu 8 years ago
Good to see you're on Instructables Kriss!! I've been following you on Youtube and had planned to make one of these soon. I'm going to try using some aluminium cam lock fittings like Ikea use for their furniture as the slanted t-slot looks a bit tricky.
Sandray123 8 years ago
Made mine about a year or so ago. Little different from yours, did not mess with pocket holes or any special angles. Used plywood sandwiched in MDF for stability and applied a coat of Poly so the router would slide smoothly. In the photos cannot see the T-tracks slots (cut with keyhole bit) on the bottom for the hold down clamps. Did not invest in expensive clamps, just took some 6" quick quick clamps and modified one end of each, to fit in the T-track. Added aluminum end plates to prevent blow outs and wear on the ends of each piece.
Wild-Bill 8 years ago
That is good video and a real beautiful and elegant jig. I like you technique for cutting the angled slot which I think I may have a use for in the future. I rarely need a jig like that, but if I did, I would do a quick one off with 4 pieces of wood. You need to know that I view myself as a wood butcher. For example my router table is just a piece of 3/4" plywood stiffened with some 2x4s and to use it, I just clamp it to my work bench and drop in my router with its fancy Veritas/LeeValley base plate. Fess tools are very nice but they are way too expensive for me and are, in my opinion, designed for old farts like myself but with way too much money. Don't get me wrong track panel saws are really nice as they make panel materials easy to cut, unless of course you have a huge shop with a nice full size cabinet saw in the middle (I would so love to have that). Many of my tools (even my panel saw, tracks and clamps) are second hand. I credit my brother-in-law, a master carpenter, for helping me become a better wood butcher as his favourite comment directed toward me was "You are not building a Piano.". I now only use extreme precession when it is really necessary. I make this point, "You are not building a Piano.", directed to your comments about sanding your jig. A quick sand to quickly round off the edges and remove splitters with 80-100 grit would be a good idea but beyond that, in my opinion, nothing. Remember, it is only a jig.
charlessenf-gm 8 years ago
Great video and a neat tool you made. However, if one could afford all those brand new Festools, why not buy the real thing?
Where'd you get all that expensive hardware?
Toolify 8 years ago
Money is still money. If it can be saved, why not? Let's be real – building a machine with a motor is a different game than a router template.
I got the hardware from Lee Valley :P Just kidding, I know what you mean. The FAQ on my site should cover it: http://fasteasysmarttool.com/faq
Cheers!
Ralphxyz 8 years ago
Wow, $360.00 for the Festool version and I like your version better.
I love the pocket hole clamping that is really great.
I have thought about using other material, but for the ease of building why bother.
If it a piece breaks just make another piece.
Now I still need to understand where to use it. I am just starting to use a router.
ILykMakin 8 years ago
Did you apply for patent before posting?
I can see some "Human"/corporation making $$ of this.
OmarJ3 8 years ago
Hi "FastEasy..."
Wonderfully detailed and clear video. However, would make suggestion. I think that plywood (or most woods, for that matter) is relatively fragile, so your T-slots could not take a lot of repeated adjusting, which can crush/fracture the wood. Instead of using regular nuts in the angled slots you might try a 2" long prism shaped steel piece with a tapped hole at center point. This type of hardware is (or was) used to clamp a kitchen sink to a counter top. I'm still drooling after looking at your shop. I WANT THOSE TOOLS :-) BTW, I've done various wood and metal work projects and often jury rig some tool on a "one off" basis. Actually built a standing cabinet from scrap "melamine" found on the street, and used IKEA style "thimble" bolt anchors. Then pocket drilled the doors to take the "invisible" style hinges with makeshift jigs. You seem to be better equipped than Norm Abram on PBS. My career was in production machinery design, and have done some house construction and serious car repair, etc. Cheers, oj
WoodCrafts 67 8 years ago
Nice Work. It looks like this would be a great jig for any workshop. I would certainly use it in mine. Great design.
Toolify 8 years ago
procter 8 years ago
I enjoy your presentation style. The content is excellent, and your style makes it even more interesting. Thanks.
Toolify 8 years ago
cestes1 8 years ago
